Custom Springs! Yay! - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 27th, 02, 09:35 AM Thread Starter
Matt Jones
Ok, I found a place near where I live (Betts Spring Co.) who will make the springs I want for $95-105 (wahoo!). I was thinking about making springs very similar to the Hotchkis (the longer bottom leaf to control wrap-up), maintain a stock Z/28 ride height, and 200lb spring rate.
What do you guys think? Is 200lb too much for street (and a couple trips a year to the drags)? And how exactly should I make the bottom leaf (to control the wheelhop)?
OH, one more thing. What size (length) U-bolt should I use with 3 leaf springs? I also need to know the diameter of the 'U'.
Thanks!
Matt
1969 Base Camaro
Vortec 350, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
http://www.geocities.com/compuboy007/
[This message has been edited by Silver69Camaro (edited 02-27-2002).]
Silver69Camaro is offline
post #2 of 7 (permalink) Old Feb 27th, 02, 10:59 AM
All the U-bolts I've seen are the same size. If they are to long, you just cut the excess off, after the nuts are on.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #3 of 7 (permalink) Old Feb 27th, 02, 07:09 PM
David Pozzi
davidpozzi's Avatar
If you like I can send you the dimensions of the Hotchkis rears I have.
Search for messages here by chicane67, he designed his own rear springs that are working really well and are similar to Guldstrand leaf's. He is using a rate over 300 lbs, which is REALLY stiff! But he says it's fine.
Hotchkis are around 160-170 lbs according to my measurements. A 200 lb spring is probably OK.
Betts is a well known company and delivers to many many truck repair shops down here.
You have Renton Coil Spring Co there too!
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
[This message has been edited by davidpozzi (edited 02-27-2002).]
davidpozzi is offline
post #4 of 7 (permalink) Old Feb 28th, 02, 12:24 AM
Sean
hey silver69, id like to hear how things turn out for you, i only live about 40 mins. from you(where's betts spring?), and ill soon be looking for a set of springs for my 68. you going to super chevy this year at sir,or "pacific raceway" as its now called.
68rs406 is offline
post #5 of 7 (permalink) Old Feb 28th, 02, 05:23 AM Thread Starter
Matt Jones
David-
I searched for Chicane's springs and I didn't find too much. What was his leaf arrangement?
I'm still playing with the spring rate. I gone from 125, to 140, then 150, and now I think I'm back at 125. Gee whiz. I want really good weight transfer on acceleration, but I don't want it to handle like a pig. I also have 380# front coils. What do you think?
I called Renton Spring, but unfortunately they don't make leaf springs, just coil. Bummer.
And yes, I'll be at the Super Chev at SIR (can't get used to Pacific Raceway). I will also be going to the Monroe swapmeet that's coming up soon. Hey, if you want, just drop by, I'll give you directions.
1969 Base Camaro
post #6 of 7 (permalink) Old Feb 28th, 02, 08:23 PM
Sean
silver 69, cool, thanks for reminding me about monroe(almost forgot). are you gonna be shopping or have a booth? pacific raceways? it'll probably always be sir to me. although id be ok w/ them bringing that track up to date a little, and getting rid of some of the freakin' rocks in the burnout box, ive got chips in my window from a few years back. hope i see you there!
68rs406 is offline
post #7 of 7 (permalink) Old Mar 12th, 02, 02:29 PM Thread Starter
Matt Jones
I got my springs today! They look well made, and they got the leafs to be exactly the way I wanted them to be (longer bottom leaf). I will be installing them shortly, so I'll let you know how the ride height is. The spring rate is around 160 lbs.
1969 Base Camaro
