Manual drum to A-body disk swap- what else is needed? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 31st, 03, 08:16 AM Thread Starter
Ben
Ok... 69 camaro stock 4 wheel manual drum brakes-
I have the whole front disk setup from a 72 Elcamino(a-body) including Booster, MC, Spindles, Rotors, Calipers, Clips, Lines, prop valve, etc etc. We pulled everything off.
Besides getting new hard lines to re-bend so this stuff will fit in the camaro, is there anything else i need to get to make this swap work?
Will the braket that holds the stock drum brake distribution block under the MC work for the Disk brake prop valve/dist block?
Thanks-
Ben
Ben R.
AHSOM70 is offline
post #2 of 4 (permalink) Old Aug 7th, 03, 07:33 AM Thread Starter
Ben
TTT- Did Anybody got their disks from an A-body?
Specifically I want to know-
1. Will there be a problem wtiht he Booster/MC hitting the hood? I read somewehre that the Booster mounting brackets might be different
2. Can I re-use some of the hard lines, or will all the lines up front have to be fabricated to work?
Thanks-
Ben
AHSOM70 is offline
post #3 of 4 (permalink) Old Aug 9th, 03, 06:59 PM
i did mine with a 71-2 monte single piston and had no problem..booster dont hit the hood, used hard lines already on car ,even used the prop valve from the old drum setup it was a square one not roundish ...the new brake hoses fit the old hard lines ..since the prop valve was relocated because of the booster spacing from the firewall a little fanaggling went on there...but i didnt have to cut and redo anything..stops like a dream
gunny is offline
post #4 of 4 (permalink) Old Aug 11th, 03, 09:44 AM Thread Starter
Ben
Thank Gunny! Thats exactly what i needed to hear!
Thanks!
Ben
AHSOM70 is offline
