A arm bushings - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 15th, 01, 07:20 PM Thread Starter
When you are putting the A arms to the car, is there any washers between chasis and bushing or between chasis and bolt and do you use anykind of locking washer? I dont know this because when I get my car front suspention and sheet metal was of the car.
Thanks.
ismail is offline
post #2 of 4 (permalink) Old Oct 15th, 01, 07:37 PM
David Pozzi
davidpozzi's Avatar
No washers, no lockwashers. Crimped self locking nuts are used.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 4 (permalink) Old Oct 15th, 01, 07:48 PM Thread Starter
Thank you David, I got grade 8 nut and bolt. What is crimped self locking nut?
ismail is offline
post #4 of 4 (permalink) Old Oct 16th, 01, 09:34 AM
David Pozzi
davidpozzi's Avatar
The nut has a lip on the top of it and it is squeezed in on two sides. This makes the nut hold tight to the bolt and not come loose.
The rocker arm nuts on a Chevy are the same type nut, just different size.
A nylock nut would be my second choice. It has a nylon ring on it to keep the nut from vibrating and loosening.
Here is a photo of a "deformed thread locknut" this is the same as the "crimped nut"
67 RS 327
[This message has been edited by davidpozzi (edited 10-16-2001).]
