Difference between BB and SB springs - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 12th, 03, 09:27 PM Thread Starter
What is the physical difference between big block and small block springs?
I just replaced my front suspension including conversion to coil overs. The springs I pulled out seem to be in good condition so I might E-bay them for a few $. The car is an SS with a 396, but I know it was originally a 350. I don't know if the guy who did the swap changed to the BB springs.
Meanchicken
68 SS
ZZ502; TKO-600; 3:73 Moser 12-bolt w/Detroit TruTrak; SSBC Force 10 4 wheel power disks;QA1 Coil Overs; Global West Tubulars;GNX Quick Ratio 12:1 PS; Hotchkis Front Sway Bar
87 Buick Grand National (does 10's)
Meanchicken is offline
post #2 of 9 (permalink) Old Aug 12th, 03, 10:30 PM
Do they still have the factory tag on them? If so, what is the letter code & part number?
jimfulco is offline
post #3 of 9 (permalink) Old Aug 13th, 03, 01:08 AM
Jonesy's Avatar
Small Block cars could have shared the same springs as big block cars. Springs were determined by the weight of the options on the car.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
post #4 of 9 (permalink) Old Aug 13th, 03, 10:15 AM
David Pozzi
davidpozzi's Avatar
Moog replacement SB springs are 300 to 327 lbs/inch in the catalog, BB springs are 327 lbs/in.
Moog replacement springs are all 5% higher rate than origonal stock GM springs.
BB springs are same rate generally as SB but taller.
Look real close for a part number stamped on the coils near the end of the spring. Some newer Moog and TRW springs are stamped.
davidpozzi is offline
post #5 of 9 (permalink) Old Aug 13th, 03, 03:44 PM
Jonesy's Avatar
Good info, David. Thanks [img]graemlins/thumbsup.gif[/img]
Jonesy is offline
post #6 of 9 (permalink) Old Aug 13th, 03, 06:06 PM
Bruno
Lightbulb
If you didn't find any numbers, at least advertise them by rate. Use this link supplied by David when I was looking for answers. Spring rate calculator
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #7 of 9 (permalink) Old Aug 13th, 03, 08:54 PM Thread Starter
Thanks for all the feedback.
I'll check for the numbers and try out David's rate calculater.
Meanchicken
68 SS
post #8 of 9 (permalink) Old Aug 14th, 03, 08:02 PM
Mean,
Have you been over to Pro-Touring's site and read up on what that gang has to say about springs since your sig. had P/T in it?? pdq67
post #9 of 9 (permalink) Old Aug 14th, 03, 08:53 PM Thread Starter
PDQ,
Yup, I've wandered through the pro-touring site a few times gleaning information. Didn't check out the spring info tho'
Guess I'll take a look. Thanks!
Meanchicken
68 SS
