New Rubber Control Arm Bushings - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 26th, 02, 05:09 AM Thread Starter
Matt Jones
Just to clear things up with rubber vs. poly bushing installation...
- Do the rubber units need to be lubed also? Where?
- Should the rubber be torqued when the car is on the ground?
- I've heard I can install them myself with out a shop press by putting the rubber bushings (control arm) in the freezer for a few hours, and they'll drop right in. Any thoughts?
1969 Base Camaro
Vortec 350, TH-400
All sheetmetal is NOS GM
Silver69Camaro is offline
post #2 of 3 (permalink) Old Jan 26th, 02, 05:27 AM
David Pozzi
davidpozzi's Avatar
no lube needed.
yes, torque with wheels on the ground
I don't know about the freezer deal. You would still have to press out the old bushings which are probably rusted in.
Why not press in the new ones then?
Be sure to put a brace between the lips of the A frame or you will squeeze them together when pressing the bushings in and out. A short piece of angle iron works well.
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer 65 Lola T-70 Chev 350 Can-Am Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old Jan 26th, 02, 03:28 PM
Joe
Talking
Thanks for the tip on angle iron, David.
joe
69 Rat-Infested Resti-Clone
WCA Member
[email protected]
69 Pics http://hobbystage.net/camaro/joeg/index.html
Joe G is offline
