Another question for David - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 30th, 01, 03:09 PM Thread Starter
Talking
Ok the steering box on my 69 is power it is about 2 1/2 turns stop to stop out of car maybe a little less. I have the long pitman arm. The outer arms leftside 3954875 rightside 3954876 is this correct? your answer will be appretiated I don't want to do this 3 or 4 times Thanks David C
[This message has been edited by Mr. C (edited 11-30-2001).]
Branded is offline
post #2 of 11 (permalink) Old Nov 30th, 01, 03:20 PM
Smile
He, He!! I'm gonna wait til David pop's in here, but I think I know his answer! LOL's pdq67
post #3 of 11 (permalink) Old Nov 30th, 01, 04:49 PM Thread Starter
Talking
Fill ME IN
Branded is offline
post #4 of 11 (permalink) Old Nov 30th, 01, 07:16 PM
David Pozzi
davidpozzi's Avatar
Yes, you have the short arms you need for power steering.
Here is a list of parts used on Camaro steering I copied from my web page.
OUTER ARMS
I have read that Corvair outer steering arms will fit camaro and are most likely the short type. (unconfirmed)
SHORT 5.25" LH-3954875 RH-3954876 Used on power steer, and Z/28 fast ratio manual.
SHORT LH-3902519 RH-3902520 turn stop pad is more pronounced on top, arm appears a bit thinner than later arms. 1968
SHORT LH-3954879 RH-3954880 (listed in parts book as 5.312" long, this may be the actual correct length for all short arms)
SHORT JL8 four wheel disc arms, 1969 Z/28 Heat Treated, Shot Peened, (probably short) LH 3916237, RH-3916238
MEDIUM ARM? I have a number for one right hand arm 5.5" length RH-3916266 The left arm is usually one number lower -3916265? not sure what ratio. Most likley used on
standard ratio power steering.
LONG 6" manual, - LH-3902517 RH-3902518 (67, early long measured at 6") LH-3917193 RH-3917194 slow ratio manual steering.
PITMAN ARMS
MANUAL LONG 5.8", 3953225 (5671822 this number was given to me but not shure of it, does not start with 39xxxxx)
MANUAL SHORT 5.25", 3953217 (on part 3953219)
POWER LONG 5.8", 3953237 (3953227 on part late, - 3908391 1967 early-thinner)
POWER SHORT 5.25", 3935711-late -3935075 3953231-327 eng -early?
CENTER LINK
large OD PS center link - 3953221
STEERING BOX- MANUAL
all manual case casting numbers are 5679142 regardless of ratio for Camaro.
manual steering gear assembly Z/28 "special fast" 20 to 1 ratio fits 67 to 81 Camaro. 7806396
manual steering gear assembly 16 to 1 ratio Monza and Vega 7819935 might fit Camaro. Listed in "Chevrolet Power" parts book.
PS PULLEYS 67-68
3744043 crank - double groove, low perf V8
3751232 crank - PS drive insert single, low perf V8
3890419 water pump double groove, low perf V8
3770509 PS pump low perf V8
3858533 crank - double deep groove, Z/28 and HP
3765947 crank - double deep groove, PS drive insert Z/28 and HP
3770245 water pump double deep groove, HP V8
3720616 water pump pulley spacer shim - reinforcement
481042 pump - single deep groove perf, HP V8 (not stock)
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
[This message has been edited by davidpozzi (edited 12-02-2001).]
davidpozzi is offline
post #5 of 11 (permalink) Old Nov 30th, 01, 08:02 PM Thread Starter
Thumbs up
Thanks alot David P looks like I'm on the right track I wont have to change anything Thanks again/ David C pdq67 is this the answer you thought David P would give?LOL HEHE
Branded is offline
post #6 of 11 (permalink) Old Dec 1st, 01, 04:52 PM
Smile
Heck, David's even longer winded then I am!! LOL!! But he knows his sh-t! He, He!! pdq67
post #7 of 11 (permalink) Old Dec 1st, 01, 06:25 PM Thread Starter
Thumbs up
You ain't wrong pdg67
Branded is offline
post #8 of 11 (permalink) Old Dec 2nd, 01, 02:48 AM
Rick
Now, PDQ67, long-winded...you?....never!
Vociferous, maybe.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips.
RickD is offline
post #9 of 11 (permalink) Old Dec 2nd, 01, 07:54 AM
Cool
Heck, another $3.00 word I'm gonna have ta look up! pdq67
post #10 of 11 (permalink) Old Dec 2nd, 01, 12:38 PM
JohnZ's Avatar
David -
The long/manual pitman arm I took off my '69Z when I converted it to P/S has forging #3953227 on it; don't know what the finished GM number is for it.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #11 of 11 (permalink) Old Dec 2nd, 01, 01:31 PM
David Pozzi
davidpozzi's Avatar
I was told a 69 arm part number is 953237. With the number you gave forged into the part.
67 RS 327
