tools for front suspension work - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 30th, 02, 04:25 AM Thread Starter
Other than some tool or "method" to keep the coil springs from shooting out and hitting something, are there any other special tools needed to replace front suspension bushings and parts (like the pst kit, for example)?
I got the helm manual and was looking at the part on front suspension and it calls out several special tools for getting bushings out/in and doing other things. Are these really required or can one improvise with regular tools?
nasadude is offline
post #2 of 10 (permalink) Old Jan 30th, 02, 04:32 AM
Matt Jones
Spring compressor is the safest way, but you can get some chain to chain up the spring so it wont become a UFO. Pickle fork for seperating the ball joints...good sized hammer (3lb?)...lots of rags.
1969 Base Camaro
Vortec 350, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
http://www.geocities.com/compuboy007/
[This message has been edited by Silver69Camaro (edited 01-30-2002).]
Silver69Camaro is offline
post #3 of 10 (permalink) Old Jan 30th, 02, 01:07 PM
choptop's Avatar
If you are going to press in your own bushings etc. you will need a big C clamp and a socket or piece of pipe to help drive in the parts. You might also need to fabricate some support members for the clamp and a-arms, so you may need access to a welder.
Everything else is pretty straight forward and can be done with normal tools.
See my '68 RS/ZZ4 at http://www.100megsfree.com/choptop/camaro.html
choptop is offline
post #4 of 10 (permalink) Old Jan 31st, 02, 01:53 AM
Lightbulb
If you are changing the pitman arm you will need a 1&5/16" socket. This socket is about one size larger than most people have. I bought a cheapo from Harbor Freight. Probably will never use it again....
Also, I highly recommend using a spring compressor. You can borrow one for free from any Autozone and keep it as long as you need it. Same thing for the pickle fork.
One last thing. Have LOTS of penetrating oil and patience. Good luck!
Dave Richard
68RS/SS Convertible
L48 (350/295 Powerglide)
daverichard is offline
post #5 of 10 (permalink) Old Jan 31st, 02, 05:10 AM
Save yourself the aggravation and take the uppers and lowers to a parts store that will replace the bushings.
I replaced my own in my stock car and it was a PIA. When I did the front suspension on my 67, I took the new bushings and the suspension parts to the local parts store and had them replace it. Yeah, you pay them labor, but IMO it was worth it.
If you do go this route, don't piant them before you drop them off. They'll mess them up.
Dean
Racer#00
67 Camaro (Almost done!)
76 Trans Am Stock Car
68 Dodge D-100 P/U
Racer#00 is offline
post #6 of 10 (permalink) Old Jan 31st, 02, 05:36 AM
Harbor Frieght has an internal spring compressor for $14. You can also pic up a pickle fork to seperate the ball joints. Then take the control arms to machine shop and have them blast clean, remove and install the bushings and ball joints.
If you want to, you can improvise with a bench vise and some "choice" sizes of pipe and angle iron spacers, to remove and install the bushings and ball joints but it is much easier with a press.
good luck,
Joe
Turbo_Jet is offline
post #7 of 10 (permalink) Old Jan 31st, 02, 05:45 AM Thread Starter
thanks for the replies.
The reason I asked the question in the first place was to determine if the "PIA" factor was low enough that I would do it myself. I really like the idea of removing the uppers and lowers myself, then taking somewhere to have the bushings changed.
I really hate the thought of paying somebody to do simple stuff that I could do, but I don't mind paying somebody for something that has a high PIA factor.
nasadude is offline
post #8 of 10 (permalink) Old Jan 31st, 02, 06:01 AM
Thumbs up
I like your approach nasadude! Always calculate the PIA Factor before beginning a project. My dad always mowed the lawn because he would only pay me 5 bucks to do it, and I figured the PIA Factor of mowing and edging for two hours was too high for just $5.
No 'E' in Camaro is offline
post #9 of 10 (permalink) Old Feb 1st, 02, 11:00 AM
My dad and I just replaced the front suspension on my 67. Took us 5 days. We probably wasted at least a day trying to remove and reinstall the control arm bushings and ball joints. Finally brought it to a shop and for $50 they did the job in an hour.
Also, the ball-joint stems were frozen in the spindles. We didn't have a torch to heat them up so we had to cut them out. That took up a good chunk of time, too.
convertibleRS is offline
post #10 of 10 (permalink) Old Feb 1st, 02, 11:23 AM
Air hammer/chisel in and out in minutes.
tracyracy is offline
