Hotckis front springs. Do they settle? - Team Camaro Tech
post #1 of 22 (permalink) Old Mar 5th, 02, 05:05 PM Thread Starter
Well I finally got some wheels on my car and took it for a little spin. I'm running Hotchkis springs in the front and rear, and the car sits to high in the front. I'd like the car to come down about 2 more inches. I hope the springs settle some. If not, I guess I'll have to cut them, but that's why I got these because I didn't want to.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #2 of 22 (permalink) Old Mar 5th, 02, 05:11 PM
Mark, are those the 2" drop springs? Did it drop the car this much from what it was. Mr. Pozzi what is the verdict on these springs? Will they settle?
navlone is offline
post #3 of 22 (permalink) Old Mar 5th, 02, 05:24 PM Thread Starter
Yeah they're the 2" drop spings. They don't look like drop springs to me at all. I took some pictures of it, I'll post them tomorrow if I get a chance.
MarkM is offline
post #4 of 22 (permalink) Old Mar 5th, 02, 05:32 PM
Rob
I put the 2" drop springs on my car a month or two ago and have a pic on the front of my web site. It does sit lower than the old springs and is exactly where I wanted it.
Rob
Rob Rice
[email protected]
http://home.attbi.com/~racrrob
RobR is offline
post #5 of 22 (permalink) Old Mar 5th, 02, 06:46 PM
David Pozzi
davidpozzi's Avatar
I think they will settle some. Did you happen to measure the free height on them before installing them?
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
davidpozzi is offline
post #6 of 22 (permalink) Old Mar 5th, 02, 06:58 PM
I just put these springs in my 67 and I noticed the difference after I drove the car a couple of times. I hope you don't have to cut them to get the stance you want, it always sucks when you have to "alter" brand new parts
shadow53 is offline
post #7 of 22 (permalink) Old Mar 5th, 02, 11:34 PM
Are you sure you got the springs right in their upper and lower pockets? I find it hard to install them, because they was sliding around over ther pockets all the time. But when i got it right and then lowered the car i couldt even pull out the floor jack, so i really hope mine doesnt settle more.
MagnusRS68 is offline
post #8 of 22 (permalink) Old Mar 6th, 02, 03:19 AM Thread Starter
David, no I didn't measure them.
Magnus, I'm pretty sure I got them in the spring pockets correctly. I had someone help me during that operation. The end of the spring lined up with the upper and lower notch.
Yeah, I don't really want to cut them. If I was going to cut springs, I could of bought the Moog for about half the price.
The thing about my car that may be different, is my car is a big block and I'm using their big block springs. I'll try to post the pics tonight when I get home.
MarkM is offline
post #9 of 22 (permalink) Old Mar 6th, 02, 06:03 AM
I just installed Hotchkis front and rear on a big block application, and have the exact same issue. Definitely higher in the front, and beyond my liking. I would be interested in what Hotchkis has to say, they must have sold alot of these by now, people must be calling them to complain. I am wondering if coils settle more than leafs, this may be the reason they come like that new from Hotchkis.
Is there a general rule regarding how much to clip to get a desired drop in ride height?
69 SS, Stroker 489, Tremec TKO, Tight Road Suspension
Mean 69 is offline
post #10 of 22 (permalink) Old Mar 6th, 02, 07:34 AM Thread Starter
I've always heard the cutting one coil will drop about 2". But there are alot of variabls like since the coil is flat on the end, will cutting the flat part off lower it 2"? What about how spring rate relates to it? Things like that. I do like the way the back springs sit though. I think I'll call Hotchkis and see what they have to say.
MarkM is offline
post #11 of 22 (permalink) Old Mar 6th, 02, 08:44 AM Thread Starter
I called Hotckis. They said to make sure the spring is seated correctly in the spring pocket. Or get the number off of it and see if it's the correct spring. Both of which I don't have to much confidence in being the right answer.
MarkM is offline
post #12 of 22 (permalink) Old Mar 6th, 02, 02:13 PM
I agree, sounds like a dead end. I will add this, I orignally had a small block in the car but decided to put the rat into it midway through the project. I have a brand new set of small block springs from Hotchkis, and compared them to the big block versions when I got them. The wire gauge is definitely bigger on the big block springs, but the free height looked pretty similar. I didn't pay too much attention to it at the time, not expecting to have an issue with it.
One question I had about my setup was that I don't have a hood on the car yet, as I am still completing the engine swap (hopefully finished this weekend, what a nightmare). In addition, I have aluminum heads, which weigh quite a bit less. I thought that maybe this was responsible, but the math doesn't add up. The spring rate is likely to be around 600 lb/in, the hundred or so pounds of less weight on my car could not "lift" the car up that much.
I think we're going to hacking springs, my friend.... By the way Mark, nice car!
Mean 69 is offline
post #13 of 22 (permalink) Old Mar 6th, 02, 07:08 PM Thread Starter
Yeah, it does look like we are going to be cutting these things. I'm going to call Hotchkis and tell them they better re-think these things. I don't think they drop the car at all over stock springs. Maybe they'll refund me the money or something. I still plan on posting some pics when I get a chance and I'll send some to Hotchkis too. I seriously want the car down another 2".
MarkM is offline
post #14 of 22 (permalink) Old Mar 7th, 02, 03:07 AM
Maybe you ask Hotchkis to swap them for SB springs?
How much more does a BB with aluminum heads weigh than a SB with iron heads?
Ken67SSRS is offline
post #15 of 22 (permalink) Old Mar 7th, 02, 05:13 AM
I used the SBC Hotchkis inch drop coils in the front and they lowered the frontend nicely and after six months of use do not appear to be sagging at all. Better check the seat on those springs and the part number.
good luck
bob spears
http://www.racehome.com/images/camaros/bspearslfront-sm.jpg
bspears is offline
