David Pozzi, Changing pressure on p/s pump - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 11th, 03, 12:59 PM Thread Starter
Hi David,
I've seen the back of these p/s pumps now so I know a little more to discuss this now. Below is a pic of the valve assembly and fitting. As you can see I numbered them to cutdown on confusion. The way I understand it you don't do anything to #1 the fitting? #2 the valve asm. gets a larger hole max .140 drilled in it where I have the letter C marking it or does it get drilled in the hole lettered B? Or am I completely wrong and it's the A hole that gets drilled (pun intended) Where is the shim located that needs to be removed and how many shims are usually on these pumps? Thanks
1967 Camaro coupe Deluxe interior LT-1 350 w/ 4spd. M-21 trans and 12 bolt rear.
RamJam is offline
post #2 of 6 (permalink) Old Aug 11th, 03, 05:54 PM
David Pozzi
davidpozzi's Avatar
None of the above.
The .140" hole is drilled in the center bore of the #1 outlet fitting. Don't drill anything else.
This is a carefully engineered flow and pressure control valve.
Don't mess with removing the washer under the "nut" in #2, some have two washers and removing one will boost pressure, but yours has only one allready and may have enough pressure as-is.
davidpozzi is offline
post #3 of 6 (permalink) Old Aug 11th, 03, 06:53 PM Thread Starter
Hey David,
Sorry for the miss info here but this isn't my valve setup I got this from archives off Chevelle Tech. I think I understand now what you mean so if the pump I get whether it's new or used has more than one washer behind that nut on part #2 I remove one of them. Then on part #1 I drill the center out larger. How deep should I go into the fitting on #1 up to the hole I lettered A or til it bottoms out? I did think that it might be in the center where it gets drilled but it looked to me to be bigger than .140 there all ready but it's hard to tell from a picture. Thanks
RamJam is offline
post #4 of 6 (permalink) Old Aug 12th, 03, 09:55 AM
David Pozzi
davidpozzi's Avatar
The restriction is just before the small side hole, there is a taper inside, it get's smaller as it goes, drill out the smallest part to .140".
post #5 of 6 (permalink) Old Aug 12th, 03, 03:22 PM
David,
If i have poor steering feel, could i add a washer or two under the nut on part #2 to reduce the pressure? What would you recommend for an incremental thickness of these shims?
Thanks,
Eugene
Aka Eugene<br />68SS350
apprentice is offline
post #6 of 6 (permalink) Old Aug 12th, 03, 05:43 PM Thread Starter
Angry
David,
I do believe I got it now. Thank you
[img]graemlins/thumbsup.gif[/img]
RamJam is offline
