Correct installation of brake booster push rod boot? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 13th, 02, 10:57 AM Thread Starter
I have a quick question of the correct installation of the white push rod boot that goes on the back of the brake booster against the fire wall.
How far inside the firewall should this part go? There is a collar where it meets the firewall. Should I force the collar through the firewall or just place the boot against the firewall? I am concerned with leaks inside the car.
Should I use a little silicon glue?
Thanks for the advice?
Sgrouse is offline
post #2 of 3 (permalink) Old Feb 13th, 02, 02:17 PM
David Pozzi
davidpozzi's Avatar
I think since the booster was designed to be quikly put on the car while on the assembly line, you should just bolt it up and it should seal. If you are worried about leakage, I think the only way it would leak is if you blasted it with a pressure washer.
If it makes you feel better you could put some silicone on it, but normally that area should not be wet, even driving in the rain.
I'd be more worried about carbon monoxide fumes more than water.
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old Feb 13th, 02, 03:40 PM
mccorry's Avatar
It just presses against the firewall. Shouldn't be a need to seal it...
Steve - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> My Camaros (updated 2/2/02)
mccorry is offline
