bench bleeding - Team Camaro Tech
post #1 of 11 (permalink) Old Aug 7th, 03, 08:49 PM Thread Starter
I just did a search on brake bleeding and found alot of threads that mention bench bleeding the m/c. What is bench bleeding and how is that done?
mark69rs is offline
post #2 of 11 (permalink) Old Aug 7th, 03, 10:48 PM
Its the process to remove all air from the master cylinder before installing onto in the car, usually at an angle trapping air inside.
Most new master cylinders ($25 at kragen) will COME with a free bench bleeding kit so you bleed it. Basically its two plastic connectors for the two outlets and some tubbing to run the fluid back into the cylinder, then while locked in a vise you pump it a bunch of times until no more bubbles and then some. hook it onto the firewall, fill up the mc the rest of the way, connect up the real brake lines.
and
Brian Lewis is offline
post #3 of 11 (permalink) Old Aug 8th, 03, 04:15 AM
Guess
HwyStarJoe's Avatar
Brian, I've been wondering the same thing because I'm almost ready to put my brakes together.
I've never bench bled one but it sounds like you can do it on the car. Just keep the resevoirs full and pump the brake pedal slowely. Does that sound right? I guess that way you can avoid spilling fluid while installing the MC. Then remove the tubes and hook up the brake lines. But I can't see how you'd avoid spewing fluid from the MC while changing connections. Will it just drip a little from the ports, if at all? It takes pumping action to force the fluid through the ports, right?
Thanks!
HwyStarJoe is offline
post #4 of 11 (permalink) Old Aug 8th, 03, 06:33 AM
Pumping action, yes.
It will have a slight drip with the lid on but remember to cover the small hole in the cover if it has one. This will not allow amb. air to leak in and allow it to pour out the fittings. If it is sealed, the vaccume effect will help retian the fluid in the cylinder in the master.
This can be done on the car, but you may not get full excursion of the piston and some air might be retained. If on the bench you can actuate it till it bottoms out, which would get more of the air out. But it can be done. I have done it a few times with success but it may require a few more bleed cycles once on the road to get the rest of the air out as is settles in the system.
chicane67 is offline
post #5 of 11 (permalink) Old Aug 8th, 03, 07:16 AM
I do not recommend doing it on the car unless you can get the rear end HIGH ENOUGH to allow the MC to be perfectly horizontal!! Else air WILL get trapped in the front most part of the piston that is above the hole on the stroke and thus you could have problems or not perfect brakes. I recently bought a new MC ($25 you can't go wrong) and bench bled it and installed it. Definitely the way to go. $25 for a newly rebuild MC is nothing when it comes to safety!!
and
post #6 of 11 (permalink) Old Aug 8th, 03, 07:50 AM
Guess
HwyStarJoe's Avatar
Ah! Thanks guys. I didn't take into account the amount of piston travel in the two setups, or the angle.
post #7 of 11 (permalink) Old Aug 8th, 03, 09:45 AM
Jon
Watch out! If you bench bleed and shove the piston in too deep or too hard you can damage the rubber seals in the master cyl, especially on dual diameter master cylinders. It really is better to do the bench bleed thing on the car. So you gotta jack the car way up, or take the front tires off, or some combination of both. The results are worth the time. Being an 'old fart', I'm lazier than most of you, but I'm really to lazy to have to do a job twice.
Jon N
dyno jonn is online now
post #8 of 11 (permalink) Old Aug 8th, 03, 10:13 AM
Oh yeah, angle. I forgot, people actually still use vaccume assisted power brakes......... [img]tongue.gif[/img]
[ 08-08-2003, 12:32 PM: Message edited by: chicane67 ]
post #9 of 11 (permalink) Old Aug 8th, 03, 10:15 AM
Guess
HwyStarJoe's Avatar
post #10 of 11 (permalink) Old Aug 8th, 03, 01:50 PM
How far should the piston be pushed?
Dan
Tire Smoke 69 is offline
post #11 of 11 (permalink) Old Aug 8th, 03, 08:27 PM
Call me Funk
Send a message via AIM to CFunK
I have followed the many bench bleeding threads and it was interesting that the MP disc brake kit I installed called for bench bleeding after installing the MC on the car.
They provided 2 plugs for the MC and the directions said to plug the 2 outputs on the MC with the plugs, fill the MC and slowly pump the brakes until there were no more air bubbles in the MC.
It worked for me and I have a great pedal feel.
-Funk
CFunK is offline
