front end height after alum heads - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 12th, 03, 09:20 AM Thread Starter
I'm getting ready to build a new small block that I'll more than likely use aluminum heads on. Problem I see is that I just got finished rebuilding the front end and used the Hotchkis 2 inch drop springs and like the height I'm at right now. Should I assume the weight diff. between my current iron heads and the "to be" alum. heads will be enough to bring the front end up a bit. Anybody experience this in their Camaro evolution? Should I add p.s and AC!
69 coupe 383 Dart,Scat,SRP...,M21, 411 12 bolt
69 ZII 350, auto,373 12 bolt
2017 Chevy SS sedan LS3
69pace is offline
post #2 of 3 (permalink) Old Aug 12th, 03, 09:20 PM
the difference should be negligable.
a/c and p/s are nice to have though.
ohcscott is offline
post #3 of 3 (permalink) Old Aug 13th, 03, 06:00 AM
I doubt you'll be able to notice any difference that you might encounter. Also, the springs may settle a little over time anyway.
- '68 Chevy Camaro (sort of done, but always subject to improvement)
- '63 Pontiac Tempest (work in progress)
- '72 Datsun 240-Z (back-burner for now)
boodlefoof is offline
