69 Z Steering Box question - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 11th, 03, 02:20 AM Thread Starter
I have a 69 Z w/o power. The entire front end is new and tight. I do, however have slack/slop in the steering. It seems to be tight going into the steering box but the output shaft is not moving in the same way. It seems that the box has excessive wear in it. My question is, there seems to be an adjustment screw/bolt, with a lock nut, right on top of the steering box. Is this an adjustment or does it control something else. If it is an adjustment, please advise on proper procedure. Thanks, any advise would be greatly appreciated.
Racer
racernum1 is offline
post #2 of 3 (permalink) Old Jul 11th, 03, 03:06 AM
Guess
HwyStarJoe's Avatar
That's the lash adjustment that you see on top of the box.
There is a lot that goes into adjusting the steering gear (steering box) as there's more than one adjustment procedure. You can adjust the lash and the worm bearing preload. The Chassis Service Manual explains it all pretty well and can help you determine whether the box has worn gears.
I can scan the pages and email them to you if you do not own the manuals.
Someone here can probably break it down for you to get you started on at least determining if it's the steering box that needs attention or not.
That is, assuming everything else in the steering assembly is in good shape.
HwyStarJoe is offline
post #3 of 3 (permalink) Old Jul 11th, 03, 04:28 PM
Tim
Depending on how many miles are on your box, it is probably worn. You might be able to adjust the lash and make it better, but make sure you follow the service manual instructions carefully.
Tim
67 Camaro RS
64 Nova SS
"Pay attention, there's gonna be a test later."
Chevy Kid is offline
