How long is brake fluid good for? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 15th, 02, 05:51 AM Thread Starter
Ken
I'm doing drum to disc conversion and replacing rear wheel cylinders too. I have a gallon can of brake fluid I've had for years. Can I use it or should I buy new? How much will be needed for full system?
Winch is offline
post #2 of 4 (permalink) Old Mar 15th, 02, 08:06 AM
If it's still in a sealed can, it should be fine. If the can has been opened, I wouldn't take a chance on it, as cheap as brake fluid is. A gallon should be more than enough.
Kyvox is offline
post #3 of 4 (permalink) Old Mar 15th, 02, 08:26 AM
Brake fluid should last forever if you dont let moisture get to it.
bowtie-70 is offline
post #4 of 4 (permalink) Old Mar 15th, 02, 01:31 PM
Buy a new can, after all, it is your brakes and you don't want to take chances and fluid is cheap.
Leo Paugh
MCC #017
If you have no fear, you're not going as fast as you could.
chev64 is offline
