Mulit's or Mono?? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 1st, 03, 07:14 PM Thread Starter
I need to replace the rear springs in my 69 because the they are starting to sag. Which is better mulit leafe or mono? This car is a weekend cruiser and an ocasional drag racer. Which will geive the best ride and hook up at the track?
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #2 of 4 (permalink) Old Aug 2nd, 03, 04:43 AM
Dano
69 racer,
I swapped my 69 coupe rear axel/mono springs for multi leafs. Immediately I noticed the difference. If your springs are over 30 years old to begin with...Then even NEW mono's will probably improve the feel. As far as hooking up @ the track...Multi's with a set of slapper bars is the way to go IMHO
Dan [img]graemlins/beers.gif[/img]
If you can't see the bright side of life, try polishing the dull side...
MrDanB is offline
post #3 of 4 (permalink) Old Aug 8th, 03, 12:47 PM
thats a very good question, I also recently switched from mono to multi, but I also swapped the front springs as well, so i do't know how much the multi's helped compared to the fronts, but I do know that I added a significant amount of weight to the rear and mostly unsprung weight at that, which is not good.
sfcamero69 is offline
post #4 of 4 (permalink) Old Aug 8th, 03, 01:45 PM
Banned
Smile
Look into JCWhitney's '68/'74 Nova type cars three-leaf mono replacement springs..
Then order mono spring matching poly for pad, fronts and rears!
And don't forget that you will probably have to trim the poly pad mount pads so use a SHARP boxknife AND be REALLY CAREFUL b/c you can cut h-ll outta yourself... pdq67
