susp identification - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 6th, 01, 04:06 AM Thread Starter
Hey I was wondering if I can get some input. I have a 67 prostreet camaro project I purchased unfinished. I need help identifying some susp components I know are unusuall(at least to me), First The frt steering linkeage is in frt of the steering knuckles. It also seems wider than what I see on 1st gen cars. Is It a latyer camaro/nove subframe? and can I cut the controll arms and mig together to correct?
My 2nd question is @ rear susp links. The are welded to the 9inch housing they seem to act as ladder bars but have no adjustability. They are 2x3 box tubing. What gives . can I use them for race I intend to race the car only no street
Milan is offline
post #2 of 4 (permalink) Old Nov 6th, 01, 07:44 AM
BC
This will be real hard to comment on without seeing it... any way you could get some pictures? Then I'm sure a number of the experts here could help you out a lot better. If it is a front steer, that means a later front suspension probably, but that does not necessarily mean a bad thing. Are you planning on keeping it as a pro streeter or looking to go back to stock? The later front will have the taller spindles among other goodies to help handle better.
I would NOT cut the control arms and re-weld, very dangerous! If it is a later model suspension, then the frame rails are wider than your stock subframe would have been, so that is where you are getting the increased width. If it really bothers you, you should look for a new front subframe that would be correct for your year, like a 67-69 Camaro/firebird or 68-72 Nova.
Good luck.
Bill C.
Bill C.
Colorado Springs, CO
68 Camaro... someday!
71 Chevelle SS
70 Nova
BC is offline
post #3 of 4 (permalink) Old Nov 6th, 01, 10:20 AM
David Pozzi
davidpozzi's Avatar
Take a look here to see if it is a Martz sub. http://www.martzchassis.com/
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #4 of 4 (permalink) Old Nov 7th, 01, 08:59 AM Thread Starter
I am not interested, at this time, to restore to stock. Any input on the rear links? Anyone?
Milan is offline
