Combination valve question. - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 24th, 01, 03:00 PM Thread Starter
I used the rear disc brakes from a Cady. I retrieved the combo valve that was attached to the frame under the fire wall. I was not able to "see" where all the brake lines ran because the car was just about flat on the ground. I took it off buy feel more than anything. Can anyone tell me where each line runs from the valve.
Thanks,
Guy
gjohnson is offline
post #2 of 3 (permalink) Old Oct 24th, 01, 03:18 PM
David Pozzi
davidpozzi's Avatar
Most of them have a brake warning sensor wire in the middle, a large port on the side for front brakes, and two small ports for each front wheel.
The rear has one line from MC in the side and the rear outlet is in the center rear end of the valve, it should be the same size as the inlet.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old Oct 25th, 01, 02:21 PM Thread Starter
Gotcha.
Thanks a bunch.
GUY
gjohnson is offline
