Booster rod removal - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 14th, 01, 07:03 AM Thread Starter
Does anyone know how to remove the rod that connects the pedal to the booster?? It seems to turn and pivot, and i was wondering if i could just pull it out? i tried a little and it not so easy.
thanks
rptherriault is offline
post #2 of 6 (permalink) Old Nov 14th, 01, 07:33 AM
There is a pin that passes thru the brake pedal, remove a clip and the pin comes out, the rod will come out with the booster.
Good Luck.
Turbo_Jet is offline
post #3 of 6 (permalink) Old Nov 14th, 01, 07:49 AM Thread Starter
yeah, that i can do...it's the rod from the booster after i removed the assembly i wish to remove.
thanx
post #4 of 6 (permalink) Old Nov 14th, 01, 08:04 AM
David Pozzi
davidpozzi's Avatar
The rod goes into a plastic hub inside the booster. It is very fragile, be careful. The rod presses on a deflection disc that allows air into the booster when brakes are applied.
I'll check my manual when I get home to see if it can be removed without splitting the booster.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #5 of 6 (permalink) Old Nov 14th, 01, 11:40 AM
David Pozzi
davidpozzi's Avatar
There is a snap ring on the inside end of the rod that must be removed.
The booster has to be completely dissassembled to do that.
67 RS 327
post #6 of 6 (permalink) Old Nov 14th, 01, 11:43 AM Thread Starter
So...I guess I won't beable to change the rod. The rod on my old booster was cut and welded to be longer...now I know why.
Thanx
