67 Idler arm - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 11th, 03, 10:54 AM Thread Starter
Why is the 67 camaro idler arm different than 68/69? It seems to cost around $20 more than 68/69's? I also can't find a new one with a 5-13/16 centers which would match my pitman arm. I'd rather not have it be on an angle acrossed the center link. Thanks
1967 Camaro coupe Deluxe interior LT-1 350 w/ 4spd. M-21 trans and 12 bolt rear.
RamJam is offline
post #2 of 4 (permalink) Old Aug 11th, 03, 01:31 PM
i went to the local Advance auto parts,and got an 1968 idler arm,and installed it.
I have not had the front end aligned,and the tires are wearing perfect,its been about 5,000
miles since i installed it,
oh and it has a lifetime warranty too!
If i ever wear it out,LOL
I sold my Camaro,hope the current owner drives it.
Email
I live near Albany,NY USA,
where are You?
cavemanmoron is offline
post #3 of 4 (permalink) Old Aug 11th, 03, 06:01 PM
David Pozzi
davidpozzi's Avatar
GM used both the short and long pitman with short idler on the 68 and 69 Camaros. So, in that respect, it has their "approval".
Replacement Moog idlers are in-between in length, at around 5.5". So, either pitman arm you use you are going to have a mis-match, unless you buy a "correct" reproduction.
Moog and TRW make replacement pitman arms, long and short for manual, and long and short for power steering which has a larger shaft.
I have the part numbers on my page, or do a search of the archives here for the list.
davidpozzi is offline
post #4 of 4 (permalink) Old Aug 11th, 03, 07:04 PM Thread Starter
Caveman,
Thanks for the info. I guess I'll be buying a 68 Idler and saving a few bucks. [img]smile.gif[/img]
David,
So that's the reason for the price difference something like 3/8 of an inch?
IF the offset is good enough for GM then I guess I can run with it. Thanks again David
RamJam is offline
