help w/ master cylinder - Team Camaro Tech
post #1 of 12 (permalink) Old Mar 16th, 02, 02:28 PM Thread Starter
I bought a master cylinder from auto zone for a 67 camaro. The only options they had was disc or drum front brakes. The master cylender has the deep hole, but how can I tell if it is for manual brakes. I converted from drum to disk and want to keep manual brakes. Part # is M1494. Any help would be great.
Thanks,
Shane
sweems is offline
post #2 of 12 (permalink) Old Mar 16th, 02, 02:45 PM
Does it look exactly like your original m/c? I shouldn't. When I bought a '67 m/c for my manual disc, it had a larger front resiviour then the rear. Because the disc calipers need more fluid then the rear drum. If your new m/c has the same size resiviours, I'd be suspisious.
MarkM is offline
post #3 of 12 (permalink) Old Mar 16th, 02, 03:00 PM Thread Starter
It is bigger than my original one, in that it will hold more fluid. But both front and back are the same size. Just to confirm, I have front disc rear drum. Had manual before and want manual still.
Thanks,
Does this sound like the wrong one.
Shane
sweems is offline
post #4 of 12 (permalink) Old Mar 16th, 02, 03:24 PM
Well I changed my car from drum to dist I put a m/c on my car from a '67 camaro with manual drums and mine was not like that. Mine had a larger front res then the rear.
MarkM is offline
post #5 of 12 (permalink) Old Mar 16th, 02, 05:39 PM Thread Starter
Just found this site, what do you guys think. http://www.classicperform.com/produc...elle/MCPVS.htm
This is how they describe the link, "67-79 Manual Master Cylinder and Proportioning Valve Kit - Disc/Drum"
Do you think this would work.
Thanks,
Shane
sweems is offline
post #6 of 12 (permalink) Old Mar 16th, 02, 09:01 PM
David Pozzi
davidpozzi's Avatar
The 67 manual disc is supposed to come with a 1" bore master cyl according to my catalog.
The manual MC should have the deep hole.
A really correct MC should look like the one in the photo you provided the link to. The front and rear reservoirs are same size on that one.
70's disc/drum MC's are interchangeable and have big front and small rear reservoirs.
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
post #7 of 12 (permalink) Old Mar 17th, 02, 09:27 AM Thread Starter
The mc that I got does have the deep hole. If I install this and its the wrong one what will happen. Will I ever know its not. And by 1" bore what bore are you talking about.
Thanks,
Shane
sweems is offline
post #8 of 12 (permalink) Old Mar 23rd, 02, 05:13 PM
Sweems,
That MC you have from Auto Zone is not a 1 inch bore. I just bought the same one and realized after I got it home that the bore was too large.
Let me know where you find one "over the counter"....I need one too.
scruff737 is offline
post #9 of 12 (permalink) Old Mar 23rd, 02, 06:58 PM
David Pozzi
davidpozzi's Avatar
Manual disc was only available in 1967 on a Camaro. If the listing does not show a MC for a 67 with manual disc, look up a 67 Corvette with manual brakes.
The piston is made of aluminum and can be seen from the rear of the MC. Measure the bore size there.
Some people have gotten by with the 1 1/8" bore Master cyl but it will increase pedal effort by maybe 20-30 lbs over a 1" bore, but use less travel.
I have been told the manual disc brakes on a Camaro allready require a lot of pedal effort with the 1" bore.
My calculations show pedal effort of 110 lbs to lock a front wheel! 140 lbs for a 1 1/8" bore master cyl.
Can anyone verify this?
[This message has been edited by davidpozzi (edited 03-23-2002).]
post #10 of 12 (permalink) Old Mar 24th, 02, 05:27 AM
David P,
What final pressure are you assuming at the brakes and what Caliper Piston Diameter with
the posted calculations? Tom V.
Boost Engineer is offline
post #11 of 12 (permalink) Old Mar 24th, 02, 04:42 PM Thread Starter
Thanks for the feedback. I will check out the 67 vette M/C tommorow and see what I come up with.
Shane
sweems is offline
post #12 of 12 (permalink) Old Mar 26th, 02, 11:48 AM Thread Starter
When at autozone and you ask for a 67 vette M/C. You will be ask for manual or power, and 1" bore or 1-1/8" bore. The Manual/1"bore part # is M1371, price is $25.99 w/ core.
Thanks for all the help,
Shane
sweems is offline
