Rag joint removal/installation tips - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 14th, 01, 04:59 AM Thread Starter
Joseph
I will be replacing my Rag joint soon and would like to know where to start. Do I loosen the steering box or do I start at the steering column? Also, Is there anyone out there with some advice to make this go nice and smooth? I did a search, but found little.
Thanks,
Joe
cam1967rsss is offline
post #2 of 4 (permalink) Old Oct 15th, 01, 04:01 AM
Gary
69Z28's Avatar
Talking
This best thing I can tell you is to remove the mounting hardware from the steering column and where the rag joint is mounted and pull the column away from the steering box. Pretty simple and straight forward operation. Just be prepare to bend over the driver fender alot and laying on the driver floor board...a pain in the butt if your a big guy.
Gary
1969 Cortez Silver Z28
69Z28 is offline
post #3 of 4 (permalink) Old Oct 15th, 01, 01:13 PM Thread Starter
Joseph
Thanks.
post #4 of 4 (permalink) Old Oct 15th, 01, 03:29 PM
Banned
Wink
I gotta!! Heck, you might as well crawl under the sucker and pull out your old box and get one of the GOOD new ones so you can turn real fast. Then you won't have ta worry about dropping your column. IMHO. pdq67
