Front Spring Question - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 14th, 02, 01:54 AM Thread Starter
choptop's Avatar
I have disassembled the front end on my '68 and totally refurbished all the parts. I painted both upper and lower arms. My question is, before I begin reassembly, is it necessary to remove paint from the lower arm spring pocket? I am concerned that the spring may turn easily on the painted surface. Should I wrap some tape (electrical tape?) around the spring ends to prevent this?
Oops, forgot to add I am putting in powdercoated Hotchkis lowering springs.
See my '68 RS/ZZ4 at http://www.100megsfree.com/choptop/camaro.html
[This message has been edited by choptop (edited 01-14-2002).]
choptop is offline
post #2 of 3 (permalink) Old Jan 14th, 02, 02:17 AM
The upper and lower spring pockets are contoured to fit the ends of the spring. Just make sure that the ends of the springs are aligned to the spring stops.
Kyvox is offline
post #3 of 3 (permalink) Old Jan 14th, 02, 06:38 AM
Once the spring finds its happy resting spot, it isn't going to shift positions regardless if it is painted or not. Since there is no drain hole in the lower a-arm, the paint will retard the on-set of rust and pitting when water collects there.
bonecrusher67conv is offline
