Putting Sub Frame Back In - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 5th, 01, 06:02 AM Thread Starter
Butch
I am going to be putting my subframe back in with new bushings in a couple of days. The question I have is there any way to make sure I have it back in correctly? I remember reading about taking measurements in an article one time but I can't find the book I read it in now. Any help or advice would be appreciated.
Old Blue is offline
post #2 of 5 (permalink) Old Dec 5th, 01, 07:51 AM
Guess
HwyStarJoe's Avatar
Old Blue,
I don't know what year you're talking about but on first gens there are 2 locating holes next to the front mounts on the subframe and corresponding tabs next to the mounts on the firewall. You can use a .610" pin of some sort in the holes to help line up the frame to the body. You should also take a tape measure and doublecheck the distance from the tab to a location you choose on the front of the subframe(such as the mounting point for the front suspension or the front point of the subframe itself. Its best to do this in a diagonal measurement making sure one side is as close to even as the other side. Now tighten your subframe bolts and re-check.
(I took some of this info from a previous post)
Do a search here on "lining up subframe" and you'll get a lot of info on it.
HwyStarJoe is offline
post #3 of 5 (permalink) Old Dec 5th, 01, 08:10 AM Thread Starter
Butch
Talking
Thanks Joe, I read it somewhere it may have been on this web site earlier in the year. I knew I had to check X but I couldn't remember from where to where to check. I will look up some back posts. I have a 69 I am working on right now. Thanks again.
Old Blue is offline
post #4 of 5 (permalink) Old Dec 6th, 01, 06:16 PM
Guess
HwyStarJoe's Avatar
No problem. Good luck with it. I'm getting ready to remove mine and I've always heard that they alomst never go together perfect. If I get mine back where it is right now, it will almost BE perfect! Let us pray......
post #5 of 5 (permalink) Old Dec 6th, 01, 07:02 PM Thread Starter
Butch
Cool
Guess what Joe I got it back in today and I got squared up within less than a 16th of an inch so I tightened it up like that. I did one back in 92 and I still have the Z. I had the front end aligned and have had no problems with that car. Now to put on all the rest of the parts, sounds like a good winter project, right. Thanks for the input and good luck with your project.
Old Blue is offline
