wandering camaro-on the highway that is - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 25th, 01, 01:30 PM Thread Starter
I own a 68 small block, it has a problem however. At highway speeds it wants to wander all over the road especially over bumps, it doesn't center very strongly either. I've had it aligned 3 times, replaced the control arm bushings, idler arm, pitman arm, inner and outer tie rods too. Don't know what else to do except maybe replace the steering gear box itself. I NEED a solution, parents are getting tired of taking pot shots at a fix, and are threatening to sell. So if anyone has any ideas help me out please.
Thanks much
fast68camaro is offline
post #2 of 10 (permalink) Old Nov 25th, 01, 02:09 PM
JohnZ's Avatar
What kind/size of tires and wheels are you using?
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #3 of 10 (permalink) Old Nov 25th, 01, 05:54 PM
Joe
How much play do you have in the steering box and has the steering box ever been adjusted?
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #4 of 10 (permalink) Old Nov 25th, 01, 06:02 PM
David Pozzi
davidpozzi's Avatar
Get the steering box adjusted first. A PS box has one adjuster on top. A manual box has two adjusters, one on the top, one on the front of the box.
Read this: http://www.monte-list.nu/tech/boxmesh.shtml STEERING BOX ADJUSTMENT
If that doesn't help, with stock springs the air tends to lift the front end at high speeds. It isn't usually a problem at 60 mph but at 100 mph it can be a big problem.
If your suspension is in good shape and you have radial tires on the car, try a front spoiler on it if you don't have one now.
Stiffer springs will help a lot.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
[This message has been edited by davidpozzi (edited 11-25-2001).]
davidpozzi is offline
post #5 of 10 (permalink) Old Nov 26th, 01, 07:28 AM
fast68, tell us about your tires. I have had two cars with this problem and both times, a new set of tires changed the car from an unmanageable tyrant to a dream to drive. If your tires are old, worn or even crummy discount tires, this may well be the problem. Is there anyone you know with new tires on their Camaro or Chevy that would let you do a swap for a short ride to see how your car responds? Also, are all of your tires matched brand and matched size? If not, expect these problems. Good luck and please let us know what you find!
denverRS/SS is offline
post #6 of 10 (permalink) Old Nov 26th, 01, 10:17 AM
Send a message via AIM to CamaroNOTcamero
David, wheres a good place to buy a front spoiler for a 67' camaro, and are there mounting holes for them on every camaro?
CamaroNOTcamero is offline
post #7 of 10 (permalink) Old Nov 26th, 01, 10:28 AM
David Pozzi
davidpozzi's Avatar
There are places to drill on the lower valance panel for the spoiler, there are braces for the ends and center.
You can use either the 68 or 69 spoiler, the 68 is slightly shorter, if your car is lowered a lot, the shorter spoiler may give better clearance.
Any of the restoration parts dealers should have them.
67 RS 327
post #8 of 10 (permalink) Old Nov 26th, 01, 01:21 PM
David, so the spoiler will bolt in or attach to something? did 67's come with a spoiler?
post #9 of 10 (permalink) Old Nov 27th, 01, 11:09 AM
Randy
rs1968ss's Avatar
Check your rag joint as well. Mine stopped after replacing it.
-Randy
Cars:
68 RS/SS BB ragtop
63 Nova II ragtop
Club:
Camaro Club of Kansas City
rs1968ss is offline
post #10 of 10 (permalink) Old Nov 27th, 01, 12:44 PM Thread Starter
Thanks for all the help folks. I adjusted my gear box and that helped alot. I am currently checking into new tires and rag joint. Thanks again
