Leaning 69 RS - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 17th, 01, 11:03 AM Thread Starter
I have a restored 69 Camaro RS that leans on the driver's side in the rear only. (I just rebuilt the front end with polygraphite bushings and new tie rods). The rear frame is bent slightly down (about an inch lower on the drivers side). Is there a way to raise the rear end about an inch on the driver's side without getting the frame straightened? The car has 5 leaf spring rear suspension. Since the body is already completed I really don't think the frame can be straingtened without bending/damaging something that is restored. Any suggestions would be appreciated.
!969 RS 355ci, vortec heads, Edelbrock performer intake, comp 270H cam, 600 Edel. carb, 4-speed muncie.
TGVThomas is offline
post #2 of 7 (permalink) Old Oct 17th, 01, 04:25 PM
Kevin
KevinW's Avatar
Thomas, Unfortunately you have a common problem for early Camaros (I have the same problem, but on 1/2 in).
There are a LOT of past posts on this subject, so please do some searches.
In a nutshell, the possible causes in no particular order are:
mismatched front or rear springs
binding or worn bushings
front spring not seated properly
worn/sagging springs
twisted subframe or body (not common, mainly accidents)
body to subframe bushings not the same thickness (may be due to rusted perches or worn out)
bent front suspension
As with mine, the problem might be the passenger front (if raised would cause the rear to go down)
Do a measurement on all the critical locations on the body and frame. Then jack up the rear with the pointy end of a piece of angle iron in the center of rear pumpkin, then measure front. The do the same to the front and measure the rear. Hopefully you can track down the reason.
Luck, Kevin
[This message has been edited by KevinW (edited 10-17-2001).]
KevinW is offline
post #3 of 7 (permalink) Old Oct 17th, 01, 04:38 PM
Yes, do a search on the subject, it's been beatin' to death many a times. I had the same problem, replaced EVERYTHING mentioned in the post above, and still it had a slight lean to the drivers side. Started out with about an 1" difference, ended up at about 1/4", just enough to hack me off. Alot of other people couldn't notice it, but I did. My final solution was to buy some air shocks, and run separate lines so I could run one side a little higher than the other, to make up the difference. The rides not as smooth, but I can definitely live with it. I'm not saying it's the best solution in the world, but it worked for me.......KZ
John D. Smith
69 SS/396 CLONE!
The Texas Tornado lives!
http://www.geocities.com/kz1000ltd/
<A HREF="http://www.fototime.com/inv/65C66018BF43AB7" TARGET=_blank>http://www.fototime.com/inv/65C66018BF43AB7[/URL]</A>
[This message has been edited by kz1000ltd (edited 10-17-2001).]
kz1000ltd is offline
post #4 of 7 (permalink) Old Oct 17th, 01, 06:00 PM
For a quick fix you could put in some longer shackles on the side that is lower or you could put in a lowering block on the side that is higher to even it out.
67firebird is offline
post #5 of 7 (permalink) Old Oct 17th, 01, 06:48 PM
I've had many Camaros and Firebird and ones that lean. I've found that the only ones that lean are the ones with mono-leaf rear springs and V-8s. I've swapped srings left to right and still it leaned.I think the rear frame rails become unlevel with age and constant torquing in opposite directions.
cavemate is offline
post #6 of 7 (permalink) Old Oct 18th, 01, 03:14 AM
I had the same problem w/ my 69. I took it to a frame shop and they checked and measured everything. I thought the frame was damaged b/c you can see that it has been pulled before from a previous accident. I replaced all the body bushings and it still had the lean. Turned out to be the body bushing "cup". Check those and you may only need some shimming to correct it. Good luck.
jay web is offline
post #7 of 7 (permalink) Old Oct 20th, 01, 02:55 AM
Eric
Yes, shims will help. If you can see the frame is bent down on one side then you could add shims between the frame and the body mount. Of course straightening the frame would be my first choice, but sometimes "you gotta do what you gotta do."
ps. welcome to the club
Eric68 is offline
