Power Steering only works when cold? - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 13th, 02, 06:09 AM Thread Starter
Hi Guys,
I got a 60 nova, and the power steering works great when I start it up and its cod, after driving it for 10 min it gets really hard to steer, as if the power steering is no longer assisting, when I stop for a while it starts working again.
Is it cavitating with air?
Am I using the wrong fluid maybe I should stick to ATF?
Is there a sticky valve?
Thanks for your help in advance.
1969 Chevy Nova 383 SB Dart 2's Roller Motor, 4.11 12 bolt TH350 10"conv
cooldude is offline
post #2 of 3 (permalink) Old Jan 13th, 02, 10:12 AM
David Pozzi
davidpozzi's Avatar
sounds like it is foaming up.
does the pump make more noise when hot? If so, then air is the problem.
Use the clear PS fluid recomended for later model cars, NOT ATF type A as stamped on some old pump caps.
ATF is not as slippery as PS clear fluid.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old Jan 13th, 02, 05:13 PM
Jack
I have an opposite problem, power steering won't work until running for a few minutes. By the way, what does a 60 nova look like ?. LOL
jackr is offline
