body bushing rusted hole... replace? - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 13th, 03, 05:17 PM Thread Starter
Jeff
guys,
just went to finish my body bushing install and noticed that the drivers side hole at the firewall is badly rusted. i want to get it fixed, but my little garage is no place to do any major work like a weld job.
so what are my options?
can i put a little plate in there temporarily and drive to a welder? or am i asking for trouble?
the bottom piece of the DSE bushings is actually big enough to cover the hole, but i dont want to take any chances.
heres a picture (the top part of the busing is setting on the frame).
what do you guys think??
thanks
1967 SS 396, M20.
now a 10.4:1 540, AFR 315 heads, UDHarold SR Cam with a Tremec TKO
jks67SS396 is offline
post #2 of 5 (permalink) Old Aug 13th, 03, 06:16 PM
joseph l clance
joe clance's Avatar
no pic appears
69 X-44 base coupe, ZZ4, 16lb nodular flywheel, Center force DF clutch + PP, Holley 600DP, Hooker super comp 1 3/4 ceramics, 2.5" dual exhaust w/ X-pipe, flowmaster 40 series mufflers.
joe clance is offline
post #3 of 5 (permalink) Old Aug 14th, 03, 02:49 AM
Guess
HwyStarJoe's Avatar
JKS,
It's hard to tell from the pic. (right-click on the red X, Properties, highlight the URL and then right-click the highlighted text, Copy, click up in the address bar then PASTE)
Is that looking down at the mount on the subframe? From the look, it's pretty darn close so I would definitely get it repaired. I'll bet the other side is the same way or close. You can use a large washer or fab an 1/8" plate to fit over the hole if you want.
HwyStarJoe is offline
post #4 of 5 (permalink) Old Aug 14th, 03, 03:59 AM
Rick
If you put some type of repair plate on, whether it's 1/8" plate like I did or a large washer, it won't go anywhere once the bolt is tightened. I don't see a problem then driving somewhere to get it welded.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #5 of 5 (permalink) Old Aug 14th, 03, 04:11 AM
Welding in a large washer works great. Make sure you go to a fastner specialist so they can get you one with the correct inside ID and thickness. Just saber saw a round hole that matches up to the OD of the washer and Mig weld it in.Plates work also, but if you go that route, you will have to put them on all six mounting positions because they are thick and replacing just a few will throw out subframe alignment.
restoman is offline
