lower ball joint - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 2nd, 01, 09:05 AM Thread Starter
I'm a high school student attempting a full restoration of a 78 camaro. I'm having trouble getting the lower ball joint out. The upper went just like the book, but I can't press out the lower. It appears it may be welded at bottom of joint. Is that how it comes from factory and how would I get it out.
Thanx
Nick K
Nick K is offline
post #2 of 4 (permalink) Old Dec 2nd, 01, 12:27 PM
David Pozzi
davidpozzi's Avatar
It is pressed in from the factory. Sometimes they are welded in if they come loose later.
Some can be pressed in very tightly. What tool are you using to remove it?
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 4 (permalink) Old Dec 2nd, 01, 02:43 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by davidpozzi:
<HR></BLOCKQUOTE>
I initially jury rigged a tool between both joints and tried to ratchet it out. This was suggested in manual. No luck. So I removed brake assembly and surrounding tie rods and have tried pounding it out with no luck
Nick K is offline
post #4 of 4 (permalink) Old Dec 2nd, 01, 03:47 PM
Send a message via AIM to CamaroNOTcamero
i used a 36 ton press , most dont have those, just take it too a suspension shop and tell them to pop it out and push new ones in, you'll have trouble putting new ones in also if you try and do it without a pres.
CamaroNOTcamero is offline
