1988 S10 Master Cylinder JB-1 or JB-3? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 14th, 03, 10:23 PM Thread Starter
Hello Camaro Guru's,
I am in the process of converting my '69's four wheel drum brakes to C4 Corvette discs, and I want to use the 1988 S10 Master Cylinder. The problem is there are two S10 Master Cylinders for manual brakes a JB-1 or a JB-3. What does this code stand for and which one should I use??? Your help is appreiated.
Thank You
-DEC
CurtiSS 69 is offline
post #2 of 3 (permalink) Old Aug 16th, 03, 06:21 PM
Bryan Shook
JB1 would have been Manual front disc/rear drums
JB3 would have been Power front disc/rear drums
I hope this helps
elcamino72 is offline
post #3 of 3 (permalink) Old Aug 17th, 03, 10:49 AM
David Pozzi
davidpozzi's Avatar
I wonder what the difference is?
Maybe the reservoir angle is tilted on the PB master cyl.
davidpozzi is offline
