Rear Disc Brake Conversion Webpage - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 12th, 01, 07:53 PM Thread Starter
I came across this website, the guy has put together a homemade conversion kit for a dana rearend using GM parts, but maybe it can be modified for Camaros. Just sharing info.
http://mopar.rockcrawler.com/brakes.htm
TEAM CANADA is offline
post #2 of 5 (permalink) Old Oct 13th, 01, 10:58 AM
i was thinking of using the rear discs off my 94 9C1 caprice. they have the drum type parking brake, and single piston PBR calipers.the bolt pattern on the rotor is wrong, but it looks like a rear off a 90's vette is the same, with the right bolt pattern.love gm's parts interchangeability.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16" IROC wheels
novaderrik is offline
post #3 of 5 (permalink) Old Oct 15th, 01, 04:35 PM
Thumbs up
Neat! Thats why I used a 5/16" plate b/c of pad fitment like he pointed out. pdq67
post #4 of 5 (permalink) Old Oct 15th, 01, 04:53 PM
He bolted the caliper braket on the backside of the mounting flange. But aren't GM brackets usually on the front? I'm pretty sure when I looked at Baer's set up on the Power Tour, their braket bolted to the front of the flange.
68 468 700R4, and here it is;
mutert23
MarkM is offline
post #5 of 5 (permalink) Old Oct 16th, 01, 07:30 AM Thread Starter
I emailed the Webmaster, he sent me the template of the caliper bracket, I plan on making it out of plywood first and mocking togehter a set-up.. using trans am rotors and caddy calipers. I think.
pdq67: Where did you get your 5/16" plate you speak of??
