Rotor Question - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 16th, 02, 09:27 AM Thread Starter
choptop's Avatar
OK, here is the deal: I am putting new wheel bearings in the rotors for my '68 Camaro. Got everything apart, popped out the old races, cleaned out the grease. One of the outer races was cracked (and spread open about 1/16") before I tried to remove it. When I put the new race in the rotor the cracked one came from, I noticed the race had lots of freeplay in the hub. Obviously this is why the previous race cracked (due to excessive clearance).
My question is do I replace this rotor with a junkyard jewel or do I go for it and buy two new one piece rotors? I have the funds to get the new ones, but the other rotor is in very good shape (original 2 piece setup) and I hate to waste good parts (sell it on e-bay?). If I buy new parts, whom do you recommend for quality and value?
[This message has been edited by choptop (edited 02-16-2002).]
choptop is offline
post #2 of 4 (permalink) Old Feb 16th, 02, 06:37 PM
David Pozzi
davidpozzi's Avatar
If you want to upgrade a bit, check out the Baer Eradispeed setup. Curved vane rotor on an aluminum hub. Uses your old caliper and brackets.
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
davidpozzi is offline
post #3 of 4 (permalink) Old Feb 17th, 02, 02:52 AM Thread Starter
choptop's Avatar
Wink
Thanks David, I'm going to check those out!
See my '68 RS/ZZ4 at http://www.100megsfree.com/choptop/camaro.html
choptop is offline
post #4 of 4 (permalink) Old Feb 17th, 02, 07:03 AM
I've got a 2 piece rotor that is beyond min. thickness, but has a good hub.You can seperate it..Or, if you do decide to go with aftermarket rotors, let me know if you're interested in selling the ones you have.
My Mountian Green 67 RS 250 6 cyl. 3-speed. Deluxe black interior,AM/FM multiplex and speed-warning. Parts car, turned resto..
http://www.members.aol.com/panther1967/camaro1a.jpg
http://members.aol.com/panther1967/camaro2a.jpg
http://members.aol.com/panther1967/camaro3a.jpg
1967 Panther is offline
