Ball joint Alteration - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 16th, 01, 05:06 PM Thread Starter
I recently swapped disk brakes onto my 69 chevelle from a 72-74 camaro. Upon installing I noticed that the ball joint studs would not come up high enough to permit the cotter pin to be pushed through. I bought new ones for the 72-74 set up but they turned out to be about an 1/8 too big around. Can they be machined to fit and would this be safe? Has anyone remedied this problem in another fashion? I would sure appreciate any opinons and ideas.
68ss camaro
69ss pro street chevelle
Tx68sscamREL is offline
post #2 of 5 (permalink) Old Dec 16th, 01, 06:51 PM
Joe
I think machining the spindle would be better than modifiying the ball joint stud.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #3 of 5 (permalink) Old Dec 17th, 01, 03:54 PM
Iv'e seen reamers for altering the size of the hole in the spindles.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
69er is offline
post #4 of 5 (permalink) Old Dec 17th, 01, 04:13 PM
Smile
There are two articles in one of the mag's called "Knuckle Sandwich" and Knuckle Sandwich Two" that tell everything you ever wanted to know about putting different spindles on the A-bodies and second gen. Camaro cars. I think they have you covered with what to do!
And, please go over to Team Chevelle and ask them, too. pdq67
post #5 of 5 (permalink) Old Dec 17th, 01, 04:41 PM
David Pozzi
davidpozzi's Avatar
I'm not sure what is done to make it work. There may be a later style lower ball joint that has turned down OD to fit the A frame.
check the team Chevelle sister site to this one.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
