Landrum Springs - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 26th, 02, 02:44 PM Thread Starter
Matt Jones
Ok guys, I'm going nuts. I've overloaded my head with suspension options and a $230 budget. My problem is that I have a mono-leaf '69 that sags on the drivers side, and I'm sure I will have a wheelhop issue.
Here I thought are my options:
1. Convert to a 4 or 5 leaf setup
2. Convert to a 3 leaf setup
3. Landrum 150# parabolic springs (not sure about spring rate)
4. Landrum medium weight (or heavy) multi- leaf springs
BUT..now I hear that I may have to replace the Landrum parabolic springs every couple of years. But what about the multileafs?
AND...I'm not sure about the idea about converting a mono-leaf car to a multi-leaf while maintaining the same perches. The 3-leaf springs may not eliminate my wheelhop (don't want any traction devices).
If anybody, and I mean ANYBODY knows the right direction to go, please let me know. I'm gettin' a headache with all this information...but it's still fun.
1969 Base Camaro
Vortec 350, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
http://www.geocities.com/compuboy007/
Silver69Camaro is offline
post #2 of 7 (permalink) Old Feb 26th, 02, 05:27 PM
David Pozzi
davidpozzi's Avatar
What is your goal for the car? Drag, street, handling?
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
davidpozzi is offline
post #3 of 7 (permalink) Old Feb 26th, 02, 05:32 PM
if you go with the landrum 5 leaf replacement from Rick's First Gen, you car will stand a little taller. I am using them on my '68. Check out my webpage to see what I mean.
www.geocities.com/boodlefoof
boodlefoof is offline
post #4 of 7 (permalink) Old Feb 26th, 02, 06:28 PM Thread Starter
Matt Jones
David-
My primary usage of the car is street, but it will see the drags a couple times a year. I am most concerned about wheelhop; which makes we want the Ladrum parabolics. But, one post says they wont last more than a couple yearsa, and that makes me want to get the 3-leaf. But then I will (probably) have wheelhop! Ack! I can see the smoke coming out of my brain already. By the way, I can't afford hotchkis springs, and I think they'll make my car sit too low (from the photos I've seen).
1969 Base Camaro
post #5 of 7 (permalink) Old Feb 26th, 02, 06:48 PM
The manufacturer of Cal-Tracts, the traction aid device for drag racing, recommends and sells the Landrum mono-leaf springs. If your on a budget I think that's the way to go. If your thinking of going multi-leaf then there is more money/time to convert the mouting perches. And about the longevity issue, a few years life time is a long time if your going to the drags often. I suspect those who have longevity issues with the Landrum mono leafs are going to the drags a lot.
Joseph
Joseph is offline
post #6 of 7 (permalink) Old Feb 27th, 02, 06:03 AM
A quesion on the comment:
"If your thinking of going multi-leaf then there is more money/time to convert the mouting perches"
My 69 was orig mono leaf. When I bought the car it has multi's installed but it does not look like the perches were changed.
Can this be true?
Thanks,
Rob
RFrenette is offline
post #7 of 7 (permalink) Old Feb 27th, 02, 06:16 AM
DjD
DjD's Avatar
<BLOCKQUOTE>quote:</font><HR>Originally posted by RFrenette:
Can this be true?
Thanks,
Rob
<HR></BLOCKQUOTE>
Here's some reading to get you up to speed on multi leaf springs in a mono perch... www.camaros.net/forum/Forum7/HTML/002835.html
...Dennis
"The '69, the '96 & the club"
DjD is offline
