Monte disk brakes - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 8th, 01, 11:51 AM Thread Starter
David,
I believe I read that you used Monte brakes on your 67. I am also using these. I know to use the steering arm from the drums, but what about the combination valve and the ball joints. I dont think the stock size lower ball joint is going to work. Am I wrong about this? Any help you could give would be appreciated. Thanks.
RACERMIKE
68 Camaro
racermike68 is offline
post #2 of 3 (permalink) Old Nov 8th, 01, 08:27 PM
David Pozzi
davidpozzi's Avatar
The monte carlo spindle fit my Camaro ball joints perfect.
Were you planning on using something else?
I'm not sure what you mean.
A monte carlo combination valve should work.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old Nov 9th, 01, 11:14 AM
Cameron
Make sure that you have a 70-72 model Monte Carlo spindle. If you don't, that may cause the problem that you are describing. I put 1970 Monte Carlo spindles on my Camaro and they fit the ball joints perfectly.
Cameron is offline
