Removing steering knuckle - Team Camaro Tech
post #1 of 14 (permalink) Old Dec 26th, 01, 08:01 PM Thread Starter
I am trying to remove the steering knuckle on a 68 Camaro for a disc brake conversion. All the hardware is loose and my "fork type" pry bar is not working. I've done this once before 10 years ago and it's driving me crazy. I don't remember taking apart the shocks or springs. I know this is simple, WHAT IS THE ANSWER? Any help? Thank you for any detailed tips!! Steve
[This message has been edited by Sgrouse (edited 12-26-2001).]
Sgrouse is offline
post #2 of 14 (permalink) Old Dec 26th, 01, 08:20 PM
Try a tierod end remover. Just make sure you leave the nut on when you press it out, that way you don't damage the threads.
Allen M is offline
post #3 of 14 (permalink) Old Dec 26th, 01, 08:27 PM Thread Starter
The "fork type" pry bar is a tierod remover.Forgot the name. It seems to be working but as soon as I pull it out, the spring or something seems to pull it all together again.
Sgrouse is offline
post #4 of 14 (permalink) Old Dec 27th, 01, 06:37 AM
BC
By steering knuckle, I assume you mean the spindle? And you are trying to pop the upper and lower ball joints loose? If that's the case, you will need to remove the shocks and let the tension on the springs loose. BE CAREFUL! If you simply pop the ball joint with nothing to catch the spring or lower control arm, you will turn the spring into a deadly missle! Once the shock is removed, loosen the castle nuts on the upper and lower ball joints to give yourself about 1/4" space, but leave the nuts on! I like to put a jack under the lower control arm with about 1/2" of space to keep it from flying down and smacking the ground, thus releasing the spring. Then use the pickle fork to 'pop' the upper and lower ball joints, which you will be able to tell once they release and get caught by the castle nuts. Once loose, I then use the jack under the lower control arm to push the arm up and release the tension on the nuts. Then simply remove the castle nuts, and then SLOWLY release the jack and lower control arm to release the spring tension. Once released, the spring should basically fall out. Then I reassemble in the reverse order with new parts as necessary.
Hope that helps,
Bill C.
Bill C.
Colorado Springs, CO
68 Camaro... someday!
71 Chevelle SS
70 Nova
BC is offline
post #5 of 14 (permalink) Old Dec 27th, 01, 05:27 PM
One thing, Bill. I think I would leave the shock in to replace the spindle, this way the sping can't completely come free.
Gary
cavemate is offline
post #6 of 14 (permalink) Old Dec 27th, 01, 07:53 PM
BC
Gary, if you are just replacing ball joint and such and are reusing the springs, then I agree. I was assuming a spring replacement...
Bill C.
BC is offline
post #7 of 14 (permalink) Old Dec 28th, 01, 08:11 AM
Smile
And if the pickle-fork doesn't do very good, then use a three pound "Ford Tool" and wrap the sides of the spindles fairly good a couple a times top and bottom to loosen the ball-joint studs. Do one end and then the other.
BUT leave the nuts on loose and BE careful!!!
Set the car up solid and use the mentioned floorjack as backup under the lower A-arm to keep the spring from popping out!! pdq67
post #8 of 14 (permalink) Old Dec 28th, 01, 12:02 PM
Try heating the steeering knuckle, and then use the tie rod fork. Just be careful and dont torch any rubber boots! Sometimes you can hit the side of the knuckle with a hammer and it will break it loose.
yogi is offline
post #9 of 14 (permalink) Old Dec 28th, 01, 12:02 PM
Pickle forks aren't usually a good idea because you can easily tear a balljoint boot. I usually just beat the sh** out of the spindle.
It will be a lot easier with the shock out, but leave a jack under the arm.
72Nova is offline
post #10 of 14 (permalink) Old Jan 2nd, 02, 03:41 PM Thread Starter
Thanks for all the help! This is a great source of info. I plan to get back @ it this weekend. I found D&R Classics to be the best deal to buy my set-up. They have a conversion set w/ used & new parts.
Sgrouse is offline
post #11 of 14 (permalink) Old Jan 3rd, 02, 07:19 AM
It really is best if you just loosen the nuts and then use the pickle fork. Don't take any thing apart until there a broke free. That way its a studier assembly to beat on.
red69camaro is offline
post #12 of 14 (permalink) Old Jan 3rd, 02, 07:50 AM
I have found the pickle forks to be a real pain. Instead, I use a 2 or three jaw gear puller. The rest of the procedure is as listed above.
Ed
Ed Bleich is offline
post #13 of 14 (permalink) Old Jan 6th, 02, 06:06 PM Thread Starter
Got them loose. Pickle fork worked but I removed the backing plate from the spindle. Got a better bite. Thanks guys. Thanks "BC".
Sgrouse is offline
post #14 of 14 (permalink) Old Jan 7th, 02, 06:19 PM
Why do they call it a pickle fork? Who uses pickle forks anyway? I just reach right into the jar..
cavemate is offline
