guldstrand or not?? - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 7th, 01, 04:41 PM Thread Starter
Talking
I think I have read every post with the words gulstrand in it. And I still dont know for sure. I was convienced to go ahead and cut them off and reweld but now I am worried about bumpsteer. I have read about it and understand what it is. Does the modification make it worse, so bad that I am going to have to bend my steering arm. I have a weekend 69 that I am building. I am putting the poly graphite bushing in it next month with a 1" sway bar. I am going to put coils in it, although I am still undecided which ones. I have read a bunch of posts but still not sure which way to go. I do want it to set lower just not sure 2" and I am not sure I want to cut coils. Do I need the Guldstrand? Will it make that much difference? Will it affect the bumpsteer? I can do the welding, that is not the problem. I am worried about the street driveablity of it? Help!!
stacy is offline
post #2 of 6 (permalink) Old Nov 7th, 01, 05:15 PM
David Pozzi
davidpozzi's Avatar
I would do it. I have a feeling it makes the bumpsteer a little worse but I woudn't let that rule my decision.
If you are not autocrossing, running open track events, or carving corners on mullholland drive, the mod is probably not as important. But it sounds like you are very capable of doing it.
I'd slide the mount rearward 3/8" too, that will make running more positive caster use less shimms.
You most likely need to bend the steering arms now, so if they need a bit more after the mod, it won't make much difference.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 6 (permalink) Old Nov 7th, 01, 06:59 PM
Joe
Exclamation
<BLOCKQUOTE>quote:</font><HR>.
[/B]<HR></BLOCKQUOTE>
David, if he doesn't do the mod, why would the steering arms need to be bent?
I'm getting ready to rebuild the front of my 69 with new lower springs, etc, so the steering arm statement got my attention.
joe
69 SS396 Resti-Clone
WCA Member
[email protected]
69 Pics http://albums.photopoint.com/j/Album...559&a=11674961
Joe G is offline
post #4 of 6 (permalink) Old Nov 7th, 01, 08:53 PM
David Pozzi
davidpozzi's Avatar
Joe,
Based on my own measurements, and confirmed by a couple of articles I've read in the magazines, the firstgen has quite a bit of toe out under bump allready.
Running more positive caster helps to reduce it by lowering the outer steering arms, but it is still there to some extent.
If you have the springs out of your car you might check what you have now and see how much toe out under bump you are getting.
I don't have the article handy but I'd bet it toes out about an eigth of an inch per inch of bump. that's 1/16" (.0625") per side. measured at the tire tread front and rear at axle height.
It should allways be measured before ever thinking about fixing it.
When mounting the steering box and idler arm, anything you can do to raise them will help bump steer. the pitman arm side holes could be slotted to help. they are on third gen Camaros.
Otherwise, the only alternative is to bend the steering arm ends down.
67 RS 327
post #5 of 6 (permalink) Old Nov 8th, 01, 05:55 PM
Joe
Talking
Thanks, David. I thought maybe I would have to bend the arms just to lower the front 1 1/2-2". I don't do much more than "cruise" so at this point the bump steer hasn't been enough bother to mess with.
For now I am just going to rebuild everything with stiffer components. If I can raise the steering box/arm without much effort, I will do so. Any advice you can give is always welcome and appreciated! Your web site is a great source of information and inspiration.
If I decide to make it more of a canyon carver in the future, I'll be picking you brain even more!
joe
WCA Member
[email protected]
Joe G is offline
post #6 of 6 (permalink) Old Nov 8th, 01, 08:31 PM
David Pozzi
davidpozzi's Avatar
Joe,
Just put the steering box and pitman arm on with upward pressure to raise them as much as possible within the normal bolt hole slop.
I haven't tried this but if you gain a quarter inch in center link height, you will probably have cut bumpsteer in half.
I don't think it is as bad on some camaros for some reason. Mine was really bad. I had close to an inch of toe out at full bump!
67 RS 327
