Rear disk brake install problem - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 18th, 01, 01:05 PM Thread Starter
Thumbs down
I'm trying to install a Master Power Brakes rear disk brake setup. The calipers mount rearward of the axle and hit the shock on the drivers side. I'm using the Competition Engineering slide-a-link traction bars. There is enough space to re-drill the lower shock mount to move it inward but there will be only about an 1/8 inch clearance between the leaf spring on one side of the shock and the same distance between the caliper and shock. Looks like a pretty tight squeeze. If I re-drill the holes, will I have any problems with the shocks hitting when the suspension is going through its motions, up and down travel and body roll etc. Open to all suggestions if this won't work. thanks
run-a-way-69 is offline
post #2 of 6 (permalink) Old Nov 18th, 01, 01:24 PM
David Pozzi
davidpozzi's Avatar
Is that a single piston caliper?
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 6 (permalink) Old Nov 18th, 01, 01:36 PM Thread Starter
The kit uses 80-85 Caddy single piston calipers and Trans Am rotors.
post #4 of 6 (permalink) Old Nov 18th, 01, 02:18 PM
Smile
Check and see if one caliper doesn't go towards the front and the other towards the rear. you can tell by looking at your calipers when they are mounted, one front and the other rear, b/c if so, both bleeders w/ be up.
The other way w/ also have both bleeders up, too, if they both go towards the back or front.
This is b/c you can't bleed an up-side-down caliper. Hope this helps. pdq67
post #5 of 6 (permalink) Old Nov 19th, 01, 05:18 AM Thread Starter
Talking
Well I found out what the problem is MP Brakes sent me the wrong kit. I need to send it back and they'll send me the correct kit.
Thanks for the help. George
post #6 of 6 (permalink) Old Nov 19th, 01, 03:07 PM
Smile
Boy, thats the easiest fix I ever saw!! Great. pdq67
