Rear Spring and Anchor plate? - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 27th, 01, 11:15 AM Thread Starter
Okay new set of questions... In my '68 I have and unknown rearend (see post in tag team, I'm trying to figure out what it came out of) When I bought the car it had monoleaf springs on it, the rearend has multi-leaf spring perches on it, the stack up was spring perch/rubber pad/mono leaf/rubber pad/ 3/8" spacer/ then all held together with T-bolts and lakewood traction bars. I don't have any lower shock plates. After disassembling this I now know why my rearend moved alot when the trans shifted hard. I feel this is less than an ideal set up. Since I already have multi leaf perches and Hotchkis springs in the front I assume my best bet would be get the Hotchkis rear leaf assemblies. How complete is thier kit? I've been to the website and it looks like they include the springs and shackles but what about u-bolts and j-nuts for the frame etc... Now my main question, I want to dump the Lakewood traction bars, they look like they have hit every speed bump in existence. On David Pozzi's website he say's he is using the Hotchkis springs but some ford lower plates? What is my best option for lower spring plates. They appear to be $40 or so apiece in the catalogs like Classic and Year One. It sure cost's a lot of money to do things the right way....
Thanks,
MStarmer
MStarmer is offline
post #2 of 9 (permalink) Old Dec 27th, 01, 05:11 PM
David Pozzi
davidpozzi's Avatar
You can get lower spring plates for a 68 from the resto vendors. Be sure to get multi leaf plates, they are thicker and the shock mount is higher up on the plate for better clearance.
I just posted some new photos and info on my rear suspension page a couple of days ago.
I'm going to cut off my old single leaf perches and use Ford type perches, U bolts, and lower plates. The lower plates are thicker and smaller than a Camaro plate.
The Hotchkis springs come with front rubber bushing, rear polly bushings only. No bolts, etc.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #3 of 9 (permalink) Old Dec 27th, 01, 05:22 PM Thread Starter
David, what about the lower spring plates on the Tuckers website, Detroit speed and engineering.
Staggered Rear Shocks: 040301R
Non-Staggered Rear Shocks: 040301L
Price:
$52.00 / pair
They seem pretty beefy.
Mike Starmer
MStarmer is offline
post #4 of 9 (permalink) Old Dec 27th, 01, 09:21 PM
I got those Spring plates and they are very good quality.
ismail is offline
post #5 of 9 (permalink) Old Dec 28th, 01, 09:22 AM Thread Starter
Ismail are you using them in a stock application and what are you using for shocks. Do you have a pic by chance of these installed? Thanks,
MStarmer
MStarmer is offline
post #6 of 9 (permalink) Old Dec 28th, 01, 06:10 PM
David Pozzi
davidpozzi's Avatar
I think the Detroit speed plates are Landrum or similar circle track type. The upper perch is like the Ford circle track type.
67 RS 327
post #7 of 9 (permalink) Old Dec 28th, 01, 06:32 PM Thread Starter
David would these work in my application with the Hotchkis springs? They look like they would. They seem to be the right price too! $52.00 a pair is a steal!
MStarmer is offline
post #8 of 9 (permalink) Old Dec 28th, 01, 09:38 PM
David Pozzi
davidpozzi's Avatar
nope, I tried my Landrum plates on my Camaro spring perches and it won't fit. The holes would have to be redrilled and they would half overlap the old holes. The plate is a bit smaller than stock and the shock mount is slightly different location, but I don't think it would cause trouble.
Maybe you can find someone who is putting on traction bars and get their old plates.
Just make sure they are from a multi leaf car.
I think second gen will work too, but the shock mount is different, just a vertical hole. You would have to get the plate modified and it could easily cost more than just buying the right thing.
Maybe swap the Lakewoods for a pair of stock plates.
67 RS 327
post #9 of 9 (permalink) Old Dec 29th, 01, 06:12 AM
David -
you might look at Chrysler perches instead of the Fords. I had the stock Ford perches on my 9" rear and they collapsed during a burnout (with mucho damage). My rearend shop said the Ford perches are wimpy and he replaced mine with Chrysler perches which are visibly much beefier. He also added heavy gussets over the open areas of the perches and fully welded them. They're plenty stout now!
Re: u-bolts - I got mine at Pep Boys and they are reasonably priced and good quality.
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
RockyMtnRacer is offline
