4 wheel disk brake set-up that fit stock rallys - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 31st, 03, 09:36 PM Thread Starter
Does anyone know who sells a good disk brake set-up that will fit inside stock rallys without using spacers?
thanks
Kelvin
1969 RS Z/28<br />1969 X-22 RS/SS
X-22 Pilot is offline
post #2 of 12 (permalink) Old Aug 1st, 03, 03:04 AM
www.baer.com They have awesome products.
69 SS
69 project for my wife - SS 396, Glacier blue
JayBird is offline
post #3 of 12 (permalink) Old Aug 1st, 03, 07:07 PM
Jeremy
are your ralley`s 14`s or 15`s? what kind of budget are you looking at for your brakes?
67 Camaro
makoshark is offline
post #4 of 12 (permalink) Old Aug 3rd, 03, 02:24 AM
I am just finishing my four wheel disk conversion using original JL8 type components. It uses the Corvette calipers and rotors. The calipers are heavier than many other options, but this was a factory option, and will fit under rally wheels. The calipers are four piston fixed units at all four corners. You will have to do some digging to get all the right pieces, but I have about $1000 in my swap. I'd be glad to answer any questions.
Ken
69 RS, 427, 4-spd<br />69 Corvette Coupe, 427, 4-spd
BB69 is offline
post #5 of 12 (permalink) Old Aug 3rd, 03, 08:11 AM
Jeremy
the JL8 brake setup only fits in 15" and larger ralley wheels. he may have 14" ralleys, but we will never know until he answer`s. there is a plethera of brake setups out there for all size wheels. it really only depends on your budget, mechanical skills and your imagination as to what you want to run.
67 Camaro
post #6 of 12 (permalink) Old Aug 3rd, 03, 09:42 PM Thread Starter
Sorry I didnt reply sooner , I have 15" rallys . Widths are : 8" with 4.5 bs rear and 7" up front. I dont mind paying for "good" stuff if they perform well.
post #7 of 12 (permalink) Old Aug 3rd, 03, 10:22 PM
a stock disc brake setup from a 69 Camaro, Nova, or Chevelle can be made to work pretty well, and is pretty much guaranteed to fit. it's the cheapest way to get initially, and easiest to find parts for on a Sunday afternoon, if need be.
you don't plan sincerity.
novaderrik is offline
post #8 of 12 (permalink) Old Aug 4th, 03, 01:01 AM
Banned
Smile
BB69,
Does your conversion JL8 calipers have the piston seals on the pistons or in the cylinder? I ask b/c the stock setup was not the best design b/c of crap getting by the seals and corroding things up.
Or so I have read from various articles..
Maybe David Pozzi will chime in here for clarification on this...
pdq67
post #9 of 12 (permalink) Old Aug 4th, 03, 01:34 AM
pdq67,
My calipers are rebuilt original Delco Moraine calipers. The common fix for these calipers is to have the bores sleeved with stainless steel. My Vette calipers are sleeved, but the ones I bought for the Camaro aren't. The only problem with sleeving the calipers, is the rebuilders don't want to touch them. I have a set of rear calipers that were sleeved and then left outside for six years. They still work fine and don't leak a bit. You are right though, these calipers are known for leaking after the bores rust.
Ken
BB69 is offline
post #10 of 12 (permalink) Old Aug 4th, 03, 11:31 AM
Jeremy
I was going to go the JL8 route until I talked to a couple of customers of Vette Brakes and Suspensions. they also directed me to a website that had alot of people not happy about their calipers. Vette Brakes is a leading manufacturer of the stainless steel sleeved calipers, so I elected to not take a chance on the having calipers that would leak brake fluid all over my freshly painted car. we all know what brake fluid can do to paint. I`m not trying to knock the JL8 setup. I`m sure it can make a camaro stop on a dime. Kelvin, you should go check out David Pozzi`s website. He has alot of stuff on their about brakes and suspensions. You can also see the front brake setup I did that uses the JL8 rotor. I built it for $340 bucks
67 Camaro
post #11 of 12 (permalink) Old Aug 4th, 03, 05:55 PM Thread Starter
thanks will visit Dave's site!
post #12 of 12 (permalink) Old Aug 5th, 03, 09:04 AM
Our 4 and 2 wheel kits will fit with disc brake rallys (most are) 15" wheels! Our drop spindle kits will work with 14" rallys with no more than 3.5" back space!
MAtt
quikchevy is offline
