68 Camaro Front Brake and Power Steering Conversion - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 28th, 16, 09:27 AM Thread Starter
Tim
Thumbs up 68 Camaro Front Brake and Power Steering Conversion
Howdy folks, new to the forum and new to First Generation Camaros. Wife and I bought our Anna out of Virginia a couple months back and are in the process of restoring her. She is a 68 SS Convertible but not numbers matching and has no power features.
Looking to add two power features - that of power front disc brakes and power steering for safety more than anything else and hoping that some of your experiences can save me time and money. Seen the kits out there but hoping I can piece together a bit cheaper (have a good friend at O'Riellys)
Any assistance will be greatly appreciated.
Tim
Sarge is offline
post #2 of 8 (permalink) Old Nov 28th, 16, 09:38 AM
George
Gbauer's Avatar
Re: 68 Camaro Front Brake and Power Steering Conversion
Calipers, spindles, brake dust shields, wheel bearings, bolts, etc can be taken from a 72 Nova.
I bought an ebay kit that worked well for me: 1964-1972 GM A F X Body - Power Disc Brake Conversion Kit Chevelle, Camaro,Nova | eBay
Something like that. Bend some lines and go at it.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #3 of 8 (permalink) Old Nov 28th, 16, 10:28 AM Thread Starter
Tim
Thanks much. Buddy can get all but the spindles for the brakes from O'Reillys. Just curious as to whether or not there are particular spindles I would need. Same with the power steering gear box if there was a particular one - the rest I can source which would save me large.
Sarge is offline
post #4 of 8 (permalink) Old Nov 28th, 16, 02:16 PM
Doug
You mean to tell me that you can get a better deal than this one from An Auto Parts Store? https://www.mattsclassicbowties.com/...-us/p3081.html
camarodriver67 is offline
post #5 of 8 (permalink) Old Nov 29th, 16, 01:10 PM
Bill
Look at this web article about spindles and calipers.
https://www.hemmings.com/magazine/hm...s/3731151.html
Caution: Try to replace the front components with stock or else you may have to replace your wheels and tires. In other words, over-sized brakes require over-sized wheels.
arocars is offline
post #6 of 8 (permalink) Old Nov 29th, 16, 01:45 PM
David Pozzi
davidpozzi's Avatar
The auto parts stores will have most of the stuff you need for a brake conversion. You will need the disc brake spindles, and caliper brackets for the conversion which are available from restoration vendors like Classic Industries or NPD. For stock appearance, you need dust shields, but I don't use them on our cars, they reduce brake cooling. If you have above average horsepower and will be using larger than stock wheels, then aftermarket brakes start making sense. Your spindles can be converted if the top boss where the drum anchor bolt screws in is cut down.
Brakes
davidpozzi is offline
post #7 of 8 (permalink) Old Nov 29th, 16, 02:56 PM
Just so you know....
What people are recommending here is the '69 & later single piston floating caliper setup, which bolts on and works fine.
Your 68 would have originally come with 4 piston fixed calipers.
BPOS is offline
post #8 of 8 (permalink) Old Nov 30th, 16, 07:09 AM
Not to hijack Sarge's thread, I'm kinda in the same boat so maybe my questions will help both of us. Will stock '68 disc spindles work on a '69 or was there a difference? I'm collecting parts and just picked up a set of Wilwood dual-piston calipers and rotors, SS lines, backing plates that fit on a '69 stock spindle and 15" rally wheels. They were mocked up and test driven a few miles, but the guy found a set of 6-piston big brakes and he jumped on them. He's going bigger on the rims of course.
IIRC wasn't there something about 2-piece hub/rotors that comes into play?
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
