69 shackle modification - Team Camaro Tech
 1Likes
post #1 of 27 (permalink) Old Dec 21st, 16, 04:21 PM Thread Starter
Question 69 shackle modification
I want to raise the back of my car 3/8". If I make a shackle 3/8" longer will it really raise the car that much or will it only lift it half that much being that its only "lifting" half the spring length. I have never done this before and I am clueless.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #2 of 27 (permalink) Old Dec 21st, 16, 05:59 PM
Vega$69's Avatar
Re: 69 shackle modification
Approx 1/2. You would need 3/4" lower bolt hole center to center to raise 3/8"
Vega$69 is offline
post #3 of 27 (permalink) Old Dec 21st, 16, 06:22 PM
DT
Donny
DT's Avatar
I personally never liked that shackle trick. Years ago you would see many cars with the extended shackles on them. IMHO not the proper way to raise a vehicle. Booster shocks (shocks with springs) raise a car approximately a 1/2 inch. I'm not even sure they still have booster shocks available though. LOL.
DT is offline
post #4 of 27 (permalink) Old Dec 21st, 16, 06:24 PM
Vega$69's Avatar
X2. Toss some KYB gas shocks on it. That will raise the rearend.
Vega$69 is offline
post #5 of 27 (permalink) Old Dec 21st, 16, 06:46 PM
DjD
DjD's Avatar
The rear end can't sit any higher than fully extended shocks will allow it and you really don't want to drive over a bump or dip and not have any extension travel. Shock extenders will help in raising the rear and keeping the car drivable if you do install taller shackles...
...Dennis
DjD is offline
post #6 of 27 (permalink) Old Dec 21st, 16, 07:21 PM
Nova leaf spring cups should raise it a bit. I think 68-72 are the years
BPOS is offline
post #7 of 27 (permalink) Old Dec 22nd, 16, 07:09 AM Thread Starter
I changed the rear springs with 2" lowering springs from summit. I was hoping it only dropped it 1.5" but it actually did lower it a full 2". That's why I was looking to get it back up 3/8" or so. Why will KYB gas shocks raise it a bit? Are they ride height adjustable?
BRICO69 is offline
post #8 of 27 (permalink) Old Dec 22nd, 16, 07:13 AM
Andrew
Andrew69's Avatar
Do you have the rubber pad between the spring and axle perch? Set the axle dirextly on the spring with spacers under the spring.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #9 of 27 (permalink) Old Dec 22nd, 16, 07:15 AM
Vega$69's Avatar
KYB always raise the rear because they are gas filled and stiff. The also ride lousey IMO.
Simpler solution it to change the lowering blocs to 1 1 /2". A lowering block will always lower the car the thickness of the block.
zdld17 likes this.
Vega$69 is offline
post #10 of 27 (permalink) Old Dec 22nd, 16, 07:30 AM Thread Starter
Can you explain that one to me, I dont' quite get what you mean. The car is pretty close to stock looking until you REALLY start staring it down. That's why I was thinking of making a 3/8" longer shackle to raise it up. You would have to crawl up under there to look to see they are longer and if I did them right it would be hard for anyone to see even if they looked. I only need to go 3/8" up. I don't really want to put the old springs back in and use 1-1/2" lowering blocks. That for sure would be more noticable.
BRICO69 is offline
post #11 of 27 (permalink) Old Dec 22nd, 16, 07:33 AM
Vega$69's Avatar
Why would you have to change the springs if you go from 2" to 1 1/2" lowering blocks?
Easier to change the blocks then then reworking or changing shackles
Vega$69 is offline
post #12 of 27 (permalink) Old Dec 22nd, 16, 07:45 AM Thread Starter
My bad... I didn't explain it correctly. I put 1-1/2" lowering springs in it that I got from Summit. I didn't use lowering blocks. That's why I said I didn't want to put the old springs back in and then use a 1-1/2" lowering block to get the ride height I'm after. I just need 3/8" up from where I'm at now. (so close yet so far)..lol.
BRICO69 is offline
post #13 of 27 (permalink) Old Dec 22nd, 16, 07:48 AM Thread Starter
I get what you are saying. That actually would get me close to 1/4" and I could live with that. I have never heard of putting the perch right on the spring without a rubber pad. Would that do anything weird to the car as far as vibration or something else?
BRICO69 is offline
post #14 of 27 (permalink) Old Dec 22nd, 16, 08:42 AM
DjD
DjD's Avatar
Mine's been like that for years and no issues... I got more like an 1/8" by doing it on the Camaro... The Nova front leaf spring mount pockets Al mentioned would be the lessor of all evils as far as handling goes.
On the Nova I added longer shackles, but it took a set of load leveling Monroe coil over shocks before the height actually changed. It's not a corner carver though...
...Dennis
DjD is offline
post #15 of 27 (permalink) Old Dec 22nd, 16, 09:10 AM Thread Starter
Thumbs up Re: 69 shackle modification
After re-reading your post I got now. Thanks.
BRICO69 is offline
