69 sub frame connectors - Team Camaro Tech
 2Likes
post #1 of 17 (permalink) Old Jan 16th, 17, 07:46 AM Thread Starter
Paul
Who's sub frame connectors do y'all recommend?
Paul O is offline
post #2 of 17 (permalink) Old Jan 16th, 17, 07:47 AM
Re: 69 sub frame connectors
If you are ok with cutting and welding Detroit Speed are the way to go.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 17 (permalink) Old Jan 16th, 17, 08:00 AM
Fred
77thor's Avatar
I like the Hotchkis SFC's... they fit nice & tight to the floors.
77thor is offline
post #4 of 17 (permalink) Old Jan 16th, 17, 08:30 AM
DT
Donny
DT's Avatar
I have the Hotchkis SFC's as well for my vert.
DT is offline
post #5 of 17 (permalink) Old Jan 16th, 17, 08:38 AM
I went with DSE connectors for my 69 since I was patching the rear floor pans anyway. They fit like a glove and when welded in and finished, they look like they are part of the car. You have to look underneath the car to see them since they don't hang down at all! VERY nice connectors!
brian2013 is offline
post #6 of 17 (permalink) Old Jan 16th, 17, 09:10 AM
Rich
rico6983's Avatar
I have the hotchkis connectors as well. Works great!
rico6983 is offline
post #7 of 17 (permalink) Old Jan 16th, 17, 09:15 AM
X3 on the Hotchkis as compared to others , the tubing is thicker. No welding. Just make sure all your body bushing are in great shape. I prefer poly but others prefer solids.
TC # 349
zdld17 is offline
post #8 of 17 (permalink) Old Jan 16th, 17, 10:39 AM
DT
Donny
DT's Avatar
No welding ??? Mine had to be welded to the frame rails. The subframe is bolted in though. The front is bolt-on or weld.
DT is offline
post #9 of 17 (permalink) Old Jan 16th, 17, 11:02 AM
mike
DSE here also, mine has lots of torque and is a convertible and the car is much much stiffer.
bigblockragtop is offline
post #10 of 17 (permalink) Old Jan 16th, 17, 12:07 PM
Apprentice
AJ
I have used Competition Engineering. Bolt in front and rear. I had to ream a couple of the holes to get them to line up.
ajviper is offline
post #11 of 17 (permalink) Old Jan 16th, 17, 12:59 PM
Chris
stinger67's Avatar
We installed the Heidts on my 67 vert. I thought they hung down too low, so I yanked them, fabbed in a couple and cut some of the floor out to raise them up.
ID:	172050   Click image for larger version
zboss86 likes this.
stinger67 is offline
post #12 of 17 (permalink) Old Jan 16th, 17, 03:36 PM
mike
That seems like the same idea as the DSE.
post #13 of 17 (permalink) Old Jan 16th, 17, 06:23 PM Thread Starter
Paul
Thanks for your input fellas.
The whiskys gone but I aint leavin
Paul O is offline
post #14 of 17 (permalink) Old Jan 16th, 17, 06:44 PM
Sorry, I should have said , welded to rear body. Front is bolted and tacked.
DT likes this.
TC # 349
zdld17 is offline
post #15 of 17 (permalink) Old Jan 17th, 17, 06:00 AM
I used Global West ...rear weld/front bolt or weld.
https://www.classicindustries.com/pr...arts/c900.html
I liked that they tucked up next to the floor with no cutting/mods...
They require solid body mounts, and I think only two are included for some reason, so you have to add two.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
