68 Z28 Lower Steering Column Bearing - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 20th, 17, 09:32 PM Thread Starter
Apprentice
Joe
Rebuilding steering column on 68 Z28 non power steering car. After renewing lower bearing cannot get snap ring back on shaft ( new bearing larger dimension). Original tolerance assembly has threads melted and cannot be adjusted. Can't find anyone who reproduces the tolerance assembly.
Any suggestions ? Joe
68 Z28 is offline
post #2 of 3 (permalink) Old Jan 21st, 17, 12:10 PM
Daryl
1968RallySport's Avatar
Re: 68 Z28 Lower Steering Column Bearing
Is this what you're looking for?
1967 - 1968 Camaro Lower Steering Column Bearing Without Tilt
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #3 of 3 (permalink) Old Jan 21st, 17, 09:27 PM Thread Starter
Apprentice
Joe
Thx
I've seen the bearing ( and have purchased one ) but between the bearing and the steering coupler flange is a " tolerance assembly" , good for one adjustment only. I suspect the tolerance assembly is designed to retain the bearing in place and take the longitudinal option out of the steering shaft.
I cannot find out whether the upgraded bearing assembly you forwarded replaces both the stock bearing arrangement and the "tolerance assembly".
Thanks again Joe
68 Z28 is offline
