68 REAR Parking Brake Cable Length - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 13th, 17, 03:50 PM Thread Starter
Bryan
Question 68 REAR Parking Brake Cable Length
My 68 originally had just the front cable and no lever inside the drum brakes. I bought the kit from Right Stuff Detailing. When I went to put in the rear cable, it seems really long between the backing plate and the first frame mount. My car does have subframe connectors, so I really hope a previous owner didn't move the mount back, but I doubt it. Looking at the chassis service manual, it looks like it is in the right place, but it looks like it might go underneath the leaf springs. Should it be this long? Am I routing it correctly? Thanks.
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, Holley Sniper EFI with Dual Sync distributor, Muncie M21 4-speed transmission, 3.73 12-bolt Eaton posi differential.
Bry68 is offline
post #2 of 4 (permalink) Old Apr 13th, 17, 04:14 PM
Re: 68 REAR Parking Brake Cable Length
It's supposed to go under the leaf spring. It looks like they sent you a cable for a stretch limo.
BPOS is offline
post #3 of 4 (permalink) Old Apr 13th, 17, 05:10 PM Thread Starter
Bryan
Okay, I'm an idiot. I was trying to put the front cable on the back. Oops.
Bry68 is offline
post #4 of 4 (permalink) Old Apr 13th, 17, 06:17 PM
Don't feel bad - I've done worse.
BPOS is offline
