What size rear wheel studs do I need for disc brakes - Team Camaro Tech
 1Likes
  • 1 Post By davidpozzi
post #1 of 4 (permalink) Old Jul 23rd, 17, 11:50 AM Thread Starter
Tony
After putting rear discs on my 68, I realize that I need longer wheel studs. What size do I need to get? All the ones I see online do not give a size...
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 4 (permalink) Old Jul 23rd, 17, 03:45 PM
Steven
stamatisg1977's Avatar
Re: What size rear wheel studs do I need for disc brakes
not much longer than stock
if you are able to without alot of hassle is just measure the thickness of the old drum mounting surface thickness and measure the disk mounting surface thickness
it usually just comes out to be a 1/2" longer stud
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 4 (permalink) Old Jul 24th, 17, 03:50 PM
David Pozzi
davidpozzi's Avatar
Take a look at a 1969 Corvette rear stud. Should be same diameter and longer due to the Corvette having disc brakes.
bondora68 likes this.
davidpozzi is offline
post #4 of 4 (permalink) Old Jul 25th, 17, 05:50 AM Thread Starter
Tony
Thanks guys!
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
