DSE lower shock plate question - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 25th, 17, 09:13 PM Thread Starter
Jeff
I did a mono to multi leaf conversion last year and used the stock mono shock plate. I am getting ready to install new shocks. I bought the DSE multi leaf shock plates along with new multi leaf shocks. My question is, has anybody reused the emergency brake cable support from the stock shock plate? Did you just leave them off?
SC42 is offline
post #2 of 5 (permalink) Old Jul 26th, 17, 07:35 AM
Eric
Re: DSE lower shock plate question
I did the same conversion and used these parking brake cable brackets.
https://www.camarocentral.com/1968_1..._p/pkb-421.htm
Eric
EN69SS396
Yellow 1969 Coupe BB396/Turbo 400
en69ss396 is offline
post #3 of 5 (permalink) Old Jul 26th, 17, 09:55 AM
X2 - use 2 of those. Mono plate pass side bracket was riveted to the plate. Would look like **** if you just let the cables hang
BPOS is offline
post #4 of 5 (permalink) Old Jul 26th, 17, 06:06 PM Thread Starter
Jeff
Thank you for the link, I ordered two of those. Did you drill holes in the new DSE plates and bolt them up?
SC42 is offline
post #5 of 5 (permalink) Old Jul 26th, 17, 07:46 PM Thread Starter
Jeff
Assembly manual shows it attached to u-bolt...Thank you again.
SC42 is offline
