Brake Bleeding - Team Camaro Tech
 4Likes
  • 3 Post By BPOS
  • 1 Post By ctcz28
post #1 of 14 (permalink) Old Jul 27th, 17, 12:30 PM Thread Starter
Elroy
Brake Bleeding
So I'm preparing to do some rear brake work on the 69 drums. I have researched and read numerous threads about people not getting fluid to either the front or rear brakes during the usual wife/girlfriend assisted brake bleeding process. It seems that the Distribution Block has a slide valve that moves when it detects a loss of pressure front or rear. If this is accurate, then it seems impossible to bleed the brakes by the traditional pumping method. You're always going to have a no pressure situation forcing the valve to move.
So if is an accurate description, then it seems that the only way to effectively bleed the brakes is by a Mithgy Vac hand pump type of system that pushes the fluid (and air) back into the master cylinder or by a pressure system that directs fluid to all four wheels at once.
What say you?
zbudman is offline
post #2 of 14 (permalink) Old Jul 27th, 17, 01:45 PM
Gordon
gordr's Avatar
Re: Brake Bleeding
The distribution block is not a valve but a pressure sensitive spool. The pic explains what it does.
credit Camaros.org graphic
Name:	Camaro first gen distribution block.jpg
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #3 of 14 (permalink) Old Jul 27th, 17, 02:04 PM Thread Starter
Elroy
Re: Brake Bleeding
So if I understand this correctly, it just activates the switch. It doesn't move to shut off fluid from the front or rear. I was under the impression that it would close down the front or rear based on detecting a loss of pressure.
Thanks for the info............
zbudman is offline
post #4 of 14 (permalink) Old Jul 27th, 17, 02:06 PM
Larry
Re: Brake Bleeding
I'm pretty sure the spool isn't spring loaded to the center. It also blocks off the leaking system when it moves to one end hence the reason one side doesn't bleed well when the valve is activated. So, it really is a valve that also activates a switch.
I believe it takes a fair amount of pressure to move the spool. Once it's moved to one side the opposite system must be opened and pressure applied to move it back into position. You can never really tell exactly where the spool is when you do this; you can only stop when the light goes out.
My method is to remove the plastic switch and fabricate a plug to thread in the block to simulate the switch with an immovable pin that keeps the spool centered as you bleed the brakes in case you get a little aggressive with the pedal pumping.
You can also purchase them.
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #5 of 14 (permalink) Old Jul 27th, 17, 02:13 PM
Larry
Re: Brake Bleeding
Look here:
https://www.camaros.net/forums/16-bra...ml#post4013162
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #6 of 14 (permalink) Old Jul 27th, 17, 03:02 PM
Gordon
gordr's Avatar
Re: Brake Bleeding
Originally Posted by 69-er View Post
That proportioning valve would be different than the distribution block the op was referring to, the newer proportioning valves tend to be all in one, eliminating the distribution block and metering valve that the original setups had. In my old all original 67, since sold, it had that setup and it was actually harder to bleed to the front brakes than the rear as it was designed to hold off the front brakes until the rears grabbed first.
Camaros.org has a good description here: Camaro Brake Valves
gordr is offline
post #7 of 14 (permalink) Old Jul 27th, 17, 03:04 PM Thread Starter
Elroy
Re: Brake Bleeding
OK, so going back to my original assessment, you will not be able to bleed the brakes the old fashion pumping way without that centering valve. Without it in place, the valve will move and prevent fluid from getting to the front or back.
I thought I'd read all the related posts and come to find out it was a fairly recent one. Thanks again for all the info and Summit page attachment.
zbudman is offline
post #8 of 14 (permalink) Old Jul 27th, 17, 03:25 PM
Gordon
gordr's Avatar
Re: Brake Bleeding
Elroy, let us know how you make out. Frustrating at times and brake fluid dripping here and there which is why I buy the cheap DOT 3 fluid gallon jug at NAPA.
gordr is offline
post #9 of 14 (permalink) Old Jul 27th, 17, 03:39 PM Thread Starter
Elroy
Re: Brake Bleeding
Will do...............
zbudman is offline
post #10 of 14 (permalink) Old Jul 27th, 17, 04:12 PM
Re: Brake Bleeding
It does not stop flow if it is off center, it's just a switch. Even if your light is on you can still bleed the old fashioned way. Once you are done bleeding the brakes and have a solid pedal with all bleeders closed, give the brake pedal a few hard stabs - this will re-center the shuttle and turn off the light.
gordr, Mike_S and oldschoolchevy like this.
BPOS is offline
post #11 of 14 (permalink) Old Jul 27th, 17, 09:51 PM
Chris
Re: Brake Bleeding
If you plan on doing this more than once or your helper resigns, get a Motive power bleeder, they are not too expensive and work really well IMO.
gordr likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #12 of 14 (permalink) Old Jul 27th, 17, 10:25 PM
Rick
Re: Brake Bleeding
Gravity bleed it. Works great.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #13 of 14 (permalink) Old Jul 28th, 17, 03:06 PM
Lyle
Re: Brake Bleeding
I use a mighty vac. The sell them at sears and are only about $60.00. Not much money if your my age and plan on bleeding out many more brake systems. I buy only the brake fluid I need to flush the entire system out once. Brake fluid absorbs water. Once a bottle is open I use it all. Don't crack the seal and put it on the shelf. Water is the worst thing for your breaking system. Keep the master cylinder full and start at the furthest brake from the master cyl move on till your done. Get caps for your bleeders. Disassemble the mighty vac when your done and wipe it down lasts longer.
akwolf is offline
post #14 of 14 (permalink) Old Jul 31st, 17, 03:18 PM Thread Starter
Elroy
Re: Brake Bleeding
Ok, over the weekend I bleed the brakes with the wife at the peddle. The reason I had to bleed the brakes in the first place was because the rear flexible line was leaking. I'm sure this was the original line.
So I go to the RR and open it and a good solid stream of fluid comes out. Same with the LR. Brakes bleed up beautifully. I then checked the old line. I blew into and very little air came out. I've read, most recently as today, that the flexible line will collapse over time. I would highly suggest to anyone having rear bleeding issues to replace this line.
As always, thanks for all the responses.
zbudman is offline
