Power Brake Booster - Team Camaro Tech
 3Likes
  • 3 Post By Larger Dave
post #1 of 2 (permalink) Old Jul 27th, 17, 04:25 PM Thread Starter
Bruce
Power Brake Booster
I need toreplace my original brake booster. Does the 8 or 9" boosters have any advantage over the stock 11"? I have 427 and need as much vac as I can. I like the look of the chrome as well
The Camaro Guy is offline
post #2 of 2 (permalink) Old Jul 27th, 17, 05:35 PM
Re: Power Brake Booster
Brake booster works on surface area. The bigger the diaphragm the less pedal effort required. It takes nearly four times the pedal effort of an 11 inch booster to operate a 7 inch booster that has only 28% of the area.
You could consider it to be a leg press for your right leg, and if you installed a super stiff spring pressure Borg & Beck pressure plate in the clutch for your left leg it would prevent you walking in a circle due to your right leg being over developed, more than your left leg.
Big Dave
The Camaro Guy, gkala and ctcz28 like this.
Larger Dave is online now
