Another bleeding rear brakes issue - Team Camaro Tech
 1Likes
  • 1 Post By ctcz28
post #1 of 9 (permalink) Old Jul 29th, 17, 01:59 PM Thread Starter
Tony
OK, I read lots of posts and I see conflicting information. I added front and rear discs. Fronts done 1 year ago, rears done a few days ago. I cannot get any fluid at all to come out of the rear. Was I supposed to change out the proportioning valve to a disc/disc valve?
I unscrewed the little brake light sensor so I could see the valve rod moving and when my wife presses the brake pedal, the valve flips to the rear rather forcefully. I slide it back with a tiny pick tool but it will not stay.
I have read that this valve shuts off the flow and I need a prop valve tool to screw in.
I also read that this valve does NOT close off the flow and that is is simply a switch for the brake light.
I also read that the master cylinder rod length is to blame.
Which of these is true??
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #2 of 9 (permalink) Old Jul 29th, 17, 03:47 PM
Rick
Re: Another bleeding rear brakes issue
Center the valve and try gravity bleeding it.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is online now
post #3 of 9 (permalink) Old Jul 29th, 17, 07:29 PM
Gordon
gordr's Avatar
Yes, you'd be wise to change to an all-in-one disc/disc proportioning valve.
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #4 of 9 (permalink) Old Jul 30th, 17, 07:51 AM
Chris
At the risk of suggesting you check a couple of things you've already done, is the bleeder valve oriented at the top of the rear calipers? If not, they won't bleed. Did you replace the flexible hose connecting the hard lines connected to the car body to the lines on the diff? If old, the rubber line can deteriorate on the inside blocking fluid flow and even acting like a check valve causing problems when bleeding. A new combination valve is a good idea to replace the old distribution block/metering valve/proportioning valve. (not sure you had all these if originally all drums).
dhutton likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #5 of 9 (permalink) Old Jul 30th, 17, 02:43 PM Thread Starter
Tony
The valve on the calipers (all) are oriented at the top. All the lines and hoses are new. My combination valve and MC are for disc/drum set up.
I have ruled out the rod length into the MC because when I changed out the rear brake lines, all of the fluid leaked out of the rear section of the MC.
I tried to gravity bleed but nothing happened.
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #6 of 9 (permalink) Old Jul 30th, 17, 03:25 PM
Orig disc/drum prop valve won't work with discs/discs.
COPO is offline
post #7 of 9 (permalink) Old Jul 30th, 17, 07:22 PM Thread Starter
Tony
OK. How are they different?
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
post #8 of 9 (permalink) Old Jul 30th, 17, 08:25 PM
Chris
Yes, you should use a disc/disc combination valve. The disc/drum combination valve has a metering valve for rear drums and with the rear discs you don't need the rear metering. Also, you stated you are using a disc/drum MC. The disc/drum MC normally has a residual pressure valve in the outlet port for the rear drums whereas a MC for disc/disc will not have the residual pressure valve. I'm not sure that either of these two changes will fix the problem with inability to bleed the rear discs, but may help avoid other braking issues. Are you sure you bled the MC properly? If you have a big air bubble in there you won't be able to bleed the brakes properly. The old school way is ok, but I prefer to use the Motive power bleeder. It doesn't cost a lot and makes it a one man procedure.
ctcz28 is offline
post #9 of 9 (permalink) Old Jul 31st, 17, 06:15 AM Thread Starter
Tony
All brakes were working fine when I changed over to rear discs so I assume the MC is bled properly. I replaced the rear hard lines, added the disc brakes and now no fluid going to rear. I can manually slide the valve with a pick tool but as soon as the pedal is pushed it moves to the rear..I guess I will replace the combination valve and bleed with the little screw-in tool.
Tony
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
  LinkBacks (?)
LinkBack to this Thread: https://www.camaros.net/forums/16-brakes-suspension-steering/435865-another-bleeding-rear-brakes-issue.html
Posted By For Type Date
Another bleeding rear brakes issue - Team Camaro Tech This thread Refback Jul 29th, 17 04:43 PM
