Ball joint stiffness - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 31st, 17, 05:28 PM Thread Starter
Hi, I could appreciate some help. I took it upon myself (probably with more than a little overconfidence) to swap my drum brakes to discs. I've taken off the old stuff and installed new ball joints and the new spindle.
I did this compressing the coil spring first, naturally. So I got the new ball joints and spindle in place, together with both control arms attached, and the thing turned easily. However, now with the load of the spring, the spindle is extremely stiff--barely budges. Is it supposed to be like this?
Thanks in advance for any help
Mike's69stroker is offline
post #2 of 6 (permalink) Old Jul 31st, 17, 05:35 PM
Re: Ball joint stiffness
Did you grease them? I usually do that before I install them and work them around a bit
BPOS is offline
post #3 of 6 (permalink) Old Jul 31st, 17, 08:21 PM
ZZ_430's Avatar
They will loosen up after driving, but like Al said grease is good.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 6 (permalink) Old Aug 1st, 17, 07:22 AM Thread Starter
Thanks guys. No I didn't lube before releasing the spring....please don't tell me I need to compress that spring again to lube (that spring compressor tool is the most diabolical contraption ever invented)!
post #5 of 6 (permalink) Old Aug 1st, 17, 07:31 AM
Kevin
Just pump them full of grease and drive it, you'll be fine. No need to compress spring again.
My '69 RS Primer driver project
KJProX is offline
post #6 of 6 (permalink) Old Aug 1st, 17, 11:52 AM Thread Starter
Sounds good. It'll be a while before I get there (based on current rate of progress, maybe October.....2019!)
